How to connect automotive sensor with 3 pins
So I have couple sensors from a car and I want to connect them and read the data from that sensors for example speed sensor it has 3 pins, ground , VCC and signal. How to interpretate that signal?
The interpretation depends on the exact type of sensor you have, the sensor input and how you are measuring the sensor output.
Helpful information can always be found in the sensor data sheet, if you can find one (often not available for OEM or proprietary parts).
I have this TO220 device with 3 pins what are they? Bad news the sensors are not the same from year to year, model to model, OEM to OEM, what does it measure, etc? Guess what we need to know?
Sure! When dealing with a car's speed sensor, it typically has three main connections: ground, power supply (VCC), and signal output. Ground provides the reference point for electrical operations, VCC supplies power usually at 5V or 12V, and the signal pin carries the actual data related to speed.
To interpret the signal:
  • If the sensor outputs a voltage, you'd measure this voltage using a voltmeter or similar device. The voltage level corresponds to the speed of the vehicle, following a specified calibration.
  • For sensors that output pulses or a frequency signal, each pulse represents a specific distance traveled. Counting these pulses over time using a frequency counter or a microcontroller helps determine the vehicle's speed based on the frequency of pulses.
Understanding the type of signal and using appropriate measurement tools allows you to accurately interpret and use the speed sensor data for monitoring or integrating into your projects effectively.
For sure it outputs a voltage, either analog or pulsed. The problem with voltmeter is that high frequency pulses might be averaged as "static" voltage.
I recommend to do at least some minimum research about that specific sensor.
