How to connect ESP32 to flask python via SOCKETIO
Hello guys, I'm having problem with SocketIO connection betwwen ESP32 (client) and flask python (server). Here is my code:
import json
import mediapipe as mp
import cv2
import io
import pickle
import numpy as np
from PIL import Image
from flask import request
from flask import Flask, render_template
from flask import jsonify
from flask_socketio import SocketIO
from bluetooth import *
import socket
import subprocess
import base64
Trimodel = pickle.load(open('model', 'rb'))
hand_signals = ['Move', 'Stop']
ip = None
mp_hands = mp.solutions.hands
hands = mp_hands.Hands(max_num_hands = 2, min_detection_confidence = 0.8, min_tracking_confidence = 0.5)
app = Flask(__name__)
socketio = SocketIO(app)
@app.route('/')
def index():
    return render_template('index.html')
@app.route('/test', methods=['POST'])
def test():
    output = request.get_json()
    imgdata = base64.b64decode(output)
    img = Image.open(io.BytesIO(imgdata))
    opencv_img = cv2.cvtColor(np.array(img), cv2.COLOR_BGR2RGB)
    opencv_img = cv2.flip(opencv_img, 1)
    opencv_img.flags.writeable = False
    results = hands.process(opencv_img)
    opencv_img.flags.writeable = True
    result = None
    if results.multi_hand_landmarks:
            hands_keypoint = []
            if len(results.multi_handedness) == 2:
                for hand in results.multi_hand_landmarks:
                    hand = convert_landmark_list(hand)
                    hands_keypoint += hand
                if (results.multi_handedness[0].classification[0].label != results.multi_handedness[1].classification[0].label):
                    if (results.multi_handedness[0].classification[0].label == 'Right'):
                        slice = int(len(hands_keypoint) / 2)
                        hands_keypoint = hands_keypoint[slice:] + hands_keypoint[:slice]
                result = Trimodel.predict([hands_keypoint])
            else:
                for side in results.multi_handedness:
                    if side.classification[0].label == 'Left':
                        hands_keypoint += [0.0] * 63
                    else:
    if result is not None:
        result = str(hand_signals[result[0]])
        socketio.emit('reply', result)
        return jsonify(result)
    result = "Not found"
    return jsonify("Not found")
@app.route('/Scan', methods=['POST'])
def Scan():
    nearby_devices = discover_devices(lookup_names=True)
    return jsonify(nearby_devices)
@app.route('/ConnectBluetooth', methods=['POST'])
def ConnectBluetooth():
    bd_addr = request.get_json()
    port = 1
    s = socket.socket(socket.AF_BLUETOOTH, socket.SOCK_STREAM, socket.BTPROTO_RFCOMM)
    try:
        s.connect((bd_addr, port))
        return ("Connected!")
    except socket.error:
        return ("{socket.error}")
    finally:
        data = subprocess.check_output(['netsh', 'wlan', 'show', 'interfaces']).decode('utf-8').split('\n')
        ssid_line = [x for x in data if 'SSID' in x and 'BSSID' not in x]
        if ssid_line:
            ssid_list = ssid_line[0].split(':')
            ssid = ssid_list[1].strip()
            ssid_info = subprocess.check_output(['netsh', 'wlan', 'show', 'profile', ssid, 'key=clear']).decode('utf-8').split('\n')
            password = [b.split(":")[1][1:-1] for b in ssid_info if "Key Content" in b]
            password = password[0]
        s.send(bytes(ssid, 'UTF-8'))
        s.send(bytes("|", 'utf-8'))
        s.send(bytes(password, 'utf-8'))
        s.send(bytes(ip, 'utf-8'))
        s.close()
def convert_landmark_list (hand):
    converted = []
    for landmark in hand.landmark:
        converted.append(landmark.x)
        converted.append(landmark.y)
        converted.append(landmark.z)
    return converted
if __name__ == "__main__":
    # app.run(host= '{}'.format(socket.gethostbyname(socket.gethostname())))
    s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
    s.connect(('10.255.255.255', 1))
    ip = s.getsockname()[0]
    socketio.run(app, host='{}'.format(ip), port=5000)
As you can see, I want to send data to ESP32 in App.Route('/test'). Here is my ESP32 code to receive it:
#include <Arduino.h>
#include <WiFi.h>
#include <WiFiMulti.h>
#include <WiFiClientSecure.h>
#include <ArduinoJson.h>
#include <WebSocketsClient.h>
#include <SocketIOclient.h>
WiFiMulti WiFiMulti;
SocketIOclient socketIO;
#define USE_SERIAL Serial
void socketIOEvent(socketIOmessageType_t type, uint8_t *payload, size_t length) {
  switch (type) {
    case sIOtype_DISCONNECT:
      USE_SERIAL.printf("[IOc] Disconnected!\n");
    case sIOtype_CONNECT:
      USE_SERIAL.printf("[IOc] Connected to url: %s\n", payload);
      // join default namespace (no auto join in Socket.IO V3)
      socketIO.send(sIOtype_CONNECT, "/");
    case sIOtype_EVENT:
        char *sptr = NULL;
        int id = strtol((char *)payload, &sptr, 10);
        USE_SERIAL.printf("[IOc] get event: %s id: %d\n", payload, id);
        if (id) {
          payload = (uint8_t *)sptr;
        DynamicJsonDocument doc(1024);
        DeserializationError error = deserializeJson(doc, payload, length);
        if (error) {
          USE_SERIAL.print(F("deserializeJson() failed: "));
          USE_SERIAL.println(error.c_str());
          return;
        String eventName = doc[0];
        USE_SERIAL.printf("[IOc] event name: %s\n", eventName.c_str());
        // Message Includes a ID for a ACK (callback)
        if (id) {
          // creat JSON message for Socket.IO (ack)
          DynamicJsonDocument docOut(1024);
          JsonArray array = docOut.to<JsonArray>();
          // add payload (parameters) for the ack (callback function)
          JsonObject param1 = array.createNestedObject();
          param1["now"] = millis();
          // JSON to String (serializion)
          String output;
          output += id;
          serializeJson(docOut, output);
          // Send event
          socketIO.send(sIOtype_ACK, output);
    case sIOtype_ACK:
      USE_SERIAL.printf("[IOc] get ack: %u\n", length);
    case sIOtype_ERROR:
      USE_SERIAL.printf("[IOc] get error: %u\n", length);
    case sIOtype_BINARY_EVENT:
      USE_SERIAL.printf("[IOc] get binary: %u\n", length);
    case sIOtype_BINARY_ACK:
      USE_SERIAL.printf("[IOc] get binary ack: %u\n", length);
  //USE_SERIAL.begin(921600);
  USE_SERIAL.begin(115200);
  //Serial.setDebugOutput(true);
  USE_SERIAL.setDebugOutput(true);
  USE_SERIAL.println();
  for (uint8_t t = 4; t > 0; t--) {
    USE_SERIAL.printf("[SETUP] BOOT WAIT %d...\n", t);
    USE_SERIAL.flush();
  // this timeout is the interval of serial data read
  WiFiMulti.addAP("cazone_staff", "lamviecnghiemtuc");
  //WiFi.disconnect();
  while (WiFiMulti.run() != WL_CONNECTED) {
    delay(100);
  String ip = WiFi.localIP().toString();
  USE_SERIAL.printf("[SETUP] WiFi Connected %s\n", ip.c_str());
  // server address, port and URL
  socketIO.begin("192.168.1.187", 5000, "/socket.io/?EIO=3");
  // event handler
  socketIO.onEvent(socketIOEvent);
  socketIO.loop();
Instead of receiving data as I thought, it keeps printing "Disconnected".
Hope you guys can help me to fix it out. Thank you!
