How to connect Java with arduino?
I hope you can answer, cuz i have tried all tutorials, but nothing...
Maybe some of you could help me out..
Thank you, cheers :wink:
The simplest way is with Processing - google it.
Java is a language, you run it in a machine, what machine.
The answer is simple through the serial port.
Can you provide a link to a tutorial that have you tried ?
What Java code is running on the PC ?
What code is running on the Arduino ?
There is a whole section of the forum dedicated to interfacing the Arduino with software on the PC. This is where you would look for advice about interfacing it with a Java application. Serial comms with Java is a bit of a PITA but Processing is essentially Java and makes the job rather easier for you, so consider using Processing instead of Java.
Could you give me some link please ? :wink:
http://playground.arduino.cc/Main/InterfacingWithSoftware
http://playground.arduino.cc/Interfacing/Java#.UxOH5V6prdU
