How to connect my arduino to node js?
I am new in arduino and node js so I have really weak understanding with this
All I need is to send the smokeLevel data to node js because I am going to create an app for this like a gauge. As you notice that I have blynk there, it is working but I want to practice on how to create my own app like blynk. Thank you for you help
here is my code in arduino correct me if I am wrong all I need is like node js
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <WiFi.h>
#include <ArduinoHttpClient.h>  // Include HTTP client for Node.js communication
#define BLYNK_TEMPLATE_ID "TMPL6DU_J0N9D"
#define BLYNK_TEMPLATE_NAME "Smoke and Gas Sensor"
#define BLYNK_AUTH_TOKEN "2EC_053aiQl9OMFxGAe90HCtZridzUhn"
#include <BlynkSimpleWifi.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
#define mq135Pin A0
#define redLEDPin 7
#define greenLEDPin 8
#define buzzerPin 10
const int smokeThreshold = 400;
const long alertInterval = 3100;
unsigned long previousMillis = 0;
char auth[] = BLYNK_AUTH_TOKEN;
char ssid[] = "ZTE_2.4G_R5fjan";  // Wifi name
char pass[] = "23WQCdNv";         // Wifi password
char serverAddress[] = "192.168.1.15";  // Node.js server address
int port = 3000;                       // Port of the server
BlynkTimer timer;
WiFiClient wifi;
HttpClient client = HttpClient(wifi, serverAddress, port);
  pinMode(redLEDPin, OUTPUT);
  pinMode(greenLEDPin, OUTPUT);
  pinMode(buzzerPin, OUTPUT);
  // Start I2C communication
  Wire.begin();
  // Initialize OLED Display
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    Serial.println("SSD1306 OLED not found!");
    while (1);
  display.clearDisplay();
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(10, 10);
  display.print("Connecting to WiFi...");
  display.display();
  Blynk.begin(auth, ssid, pass);
  // Connect to WiFi
  WiFi.begin(ssid, pass);
    Serial.println("Connecting to WiFi...");
  Serial.println("Connected to WiFi");
  display.print("WiFi Connected!");
  display.display();
  delay(2000);
  Blynk.run();
  // Read MQ-135 sensor
  int smokeLevel = analogRead(mq135Pin);
  Serial.print("Smoke Level: ");
  Serial.println(smokeLevel);
  // DATASTREAMS
  Blynk.virtualWrite(V0, smokeLevel);
  // Update OLED
  display.print("Smoke Level: ");
  display.print(smokeLevel);
  if (smokeLevel > smokeThreshold) {
    display.setCursor(10, 30);
    display.print("SMOKE ALERT! ");
    display.setCursor(10, 50);
    display.print("POSSIBLE FIRE!");
       // Blynk.logEvent({EVENT_CODE}, {MESSAGE})
    Blynk.logEvent("smoke_and_gas_sensor", "🚨 ALERT: Smoke/Gas Detected! 🚨\n\n"
    "Warning! Smoke or gas has been detected in your house. Please check immediately and take necessary precautions. If needed, evacuate and contact emergency services.");
    // Sending the smoke data to Node.js server
    sendSmokeData(smokeLevel);
    Serial.println("SMOKE ALERT! ");
    digitalWrite(redLEDPin, HIGH);
    digitalWrite(greenLEDPin, LOW);
    if (currentMillis - previousMillis >= alertInterval) {
      digitalWrite(buzzerPin, HIGH);
      digitalWrite(buzzerPin, LOW);
    display.print("Safe Environment");
    Serial.println("Safe Environment");
    digitalWrite(redLEDPin, LOW);
    digitalWrite(greenLEDPin, HIGH);
  Blynk.run();
  timer.run();
  display.display();
// Function to send smoke level data to Node.js server
void sendSmokeData(int smokeLevel) {
  Serial.println("Sending smoke data to Node.js server...");
  String url = "/smoke_alert";  // Define the endpoint
  String jsonData = "{\"smokeLevel\": " + String(smokeLevel) + "}";  // Convert smoke level to JSON
  client.beginRequest();
  client.post(url);
  client.sendHeader("Content-Type", "application/json");
  client.sendHeader("Content-Length", jsonData.length());
  client.sendHeader("Connection", "close");
  client.beginBody();
  client.print(jsonData);  // Send the JSON data
  int statusCode = client.responseStatusCode();
  String response = client.responseBody();
  Serial.print("Status code: ");
  Serial.println(statusCode);
  Serial.print("Response: ");
  Serial.println(response);
Topic moved. Please do not post in "Uncategorised"; see the sticky topics in Uncategorized - Arduino Forum.
Welcome to the forum.
If you would like to read how to handle POST requests in node.js, here is an article that may help to get you started.
Thank you
