How to connect NodeMCU with NRF24L01
Currently i'm trying to send integer data using nrf24l01 from arduino uno to esp8266. But the serial monitor for nodemcu is not displaying any integer data.
This is my code for arduino uno(transmitter)
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(7, 8); // CE, CSN
const byte address[6] = "00001";
  Serial.begin(9600);     // Communication started with 9600 baud
  radio.begin();
  radio.openWritingPipe(address);
  radio.setPALevel(RF24_PA_MIN);
  radio.stopListening();
  int sensor=analogRead(A0);
  radio.write(&sensor, sizeof(sensor)); // Incoming analog signal read and appointed sensor
  Serial.println(sensor);   //Wrote serial port
and this is my code for nodemcu esp8266 (receiver)
#include <ESP8266WiFi.h>
#include <SPI.h>
#include <RF24.h>
#define WIFI_SSID "otwtoy"
#define WIFI_PASSWORD "jangsorangje"
//basic SPI and the newly installed RF24 libraries
//and create an RF24 object
RF24 radio(D4, D8); // CE, CSN
//create a byte array which will represent the address, or the
//so called pipe through which the two modules will communicate
//data type declaration to keep the value sensor
//int value;
  radio.begin();
  //Connecting to WIFI
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("connecting");
      Serial.print(".\n");
  Serial.print("connected: ");
  //set the same address and in that way we enable
  //the communication between the two modules
  radio.openReadingPipe(1, address);
  //set the Power Amplifier level, in our case I will set
  //it to minimum as my modules are very close to each other
  //sets the module as receiver
  radio.startListening();
  if (radio.available()) {
        int text = 0;
        radio.read(&text, sizeof(text));
        Serial.println(text);
  else{
    //not receive any data
    Serial.println("Krik2");
this is the wiring for nodemcu esp8266
Wiring Nodemcu
and the result :-
Result
