How to connect P10 DMD to Arduino Mega 2560?
Just throwing this out there in case I get lucky. Purchased a P10 32x16 PMD to use with my Mega but can't seem to get the software or hardware figured out, not sure which.
I'm basically adapting this guide for the Uno to the Mega: LED Display Board using P10 LED Matrix Display and Arduino
Based on several threads, I've modified the DMD.h file to change to pins 51 and 52, as I understand this has something to do with the Mega using different pins for the SPI feature:
#define PIN_DMD_CLK 52
#define PIN_DMD_R_DATA 51
I am maybe also supposed to change #define PIN_OTHER_SPI_nCS from 10 to 1, i.e. #define PIN_OTHER_SPI_nCS 1, per this thread? Arduino mega using dmd library (SOLVED) -Freetronics Forum
To give the matrix power, I first tried connecting 3 AA batteries in series to achieve 4.5 volts. Since it wasn't working, I tried switching the power to the Mega's 5V connection, since I read that the lights should still work but would just be dim.
Nothing seems to be working, though. I'm not sure if I've just wired something wrong, but my guess is that it's a software problem. Any thoughts?
First of the all - the matrix should be powered from external 5v power supply with current output at least 0.5A(for one or two panels). You can power matrix from the 5v Arduino pin ONLY when your Arduino powered from the USB.
About software - I run these matrices with stm32 boards, not Mega...
By the way. in order to check - it's in the hardware or in the software problem - run the matrix with Uno/Nano
