How to connect PIR to Arduino Mega + Code?
I am trying to make a touch activated mp3 player using Arduino Mega, PIR sensor and DFPlayer.
However, I am confused as to how to connect the PIR to Arduino Mega. Where is the sensor pin located on Arduino Mega?
With reference to the code below by @UptownKitten , why are there two sensor pins and how should i modify the code if I only need 1 sensor pin?
/*Software from Mert Arudino:
https://www.hackster.io/mertarduino/how-to-make-a-talking-pir-motion-security-system-d74e0a
Special thanks to all who helped as well:
https://forum.arduino.cc/index.php?topic=657163.msg4431743#msg4431743
#include <DFPlayerMini_Fast.h>
DFPlayerMini_Fast myMP3;
void printDetail(uint8_t type, int value);
#define SENSORPIN 7
#define SENSOR2PIN 6
#define PAUSETIME 2000
byte SENSORCOUNT = 1;
byte SENSOR2COUNT = 0;
  Serial1.begin(9600);
  pinMode(SENSORPIN, INPUT);
  pinMode(SENSOR2PIN, INPUT);
  Serial.println(F("Initializing DFPlayer..."));
  //Use softwareSerial to communicate with MP3
  if (!myMP3.begin(Serial1)) {
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
    while(true);
  Serial.println(F("DFPlayer Mini online."));
  //Set volume value (From 0 to 30)
  myMP3.volume(30);
void sensor2Activated() {
  int IRSensor = digitalRead(SENSOR2PIN);
  if(IRSensor == LOW && SENSOR2COUNT == 0)
    SENSOR2COUNT++;
    Serial.println("Sensor Activated");
    Serial.println("DFPlayer Working...");
    myMP3.play(9);
  else{
    myMP3.sleep();
  return;
void sensorActivated() {
  int pirSensor = digitalRead(SENSORPIN);
  if(pirSensor == HIGH && SENSORCOUNT == 1)
    SENSORCOUNT++;
    myMP3.play(10);
    delay(1500);
  else{
    myMP3.sleep();
  return;
  sensorActivated();
  sensor2Activated();
  delay(PAUSETIME);
Well it looks like the code is expected it connected to these pins...
Um... remove the code related to the 2nd sensor.
    SENSOR2COUNT++;
    myMP3.play(9);
  else{
    myMP3.sleep();
  return;
Okay, thank you for your help :slight_smile:
