How to connect Raspberry PI 3 B to two Bluetooth modules or more using Linux Commands
I'm working on a project; that needs to send data from the two Arduinos using two Bluetooth Module (One using HC-06 and the other using HC-05) to Raspberry PI 3 B; so that the RPi 3 need to connect to two Bluetooths at once, Thank you.
Have you checked the Bluetooth standards to be sure that is possible?
i found that it is possible to connect until 8 devices to one Raspberry Pi
connecting multiple Bluetooth Classic devices is certainly possible - the RPi just has to pair with them
I have used simple serial transmission between a Arduino and HC-05 and HC-06 to a RPi
