How to connect XGZP6899D differential pressure sensor with Arduino Uno? Can I just use female to male jumper wire?
XGZP6899D datasheet ( https://www.cfsensor.com/static/upload/file/20220929/XGZP6899D%20Pressure%20Sensor%20V2.6.pdf )
Do you just have the sensor or is it mounted on a breakout board?
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project
See About the Installation & Troubleshooting category.
Only have the sensor
I suspect that it will be extremely unreliable. Also, don't forget that you need a decoupling capacitor as shown in the datasheet (100nF ceramic).
I would get some stripboard and solder the chip and ceramic capacitor on it. Solder wires to the stripboard and wire that to your Uno.
I don't think the legs on the chip are long enough to connect to a jumper wire. You could cut the female ends off, strip a millimeter or two of insulation off, and solder directly to the pins. You'll need a capacitor between pins 2 (ground) and 6 (power).
