Hi , I want to constrain an exist library with addition constrain, code like this
[code]
#ifdef Trans
typedef MAX3421e<P53, P18> MAX3421E; // trans
#elif BOARD_BLACK_WIDDOW
typedef MAX3421e<P6, P3> MAX3421E; // Black Widow
#elif defined(BOARD_TEENSY_PLUS_PLUS)
typedef MAX3421e<P9, P8> MAX3421E; // Teensy++ 2.0 & 1.0
#elif defined(BOARD_MEGA_ADK)
typedef MAX3421e<P53, P54> MAX3421E; // Arduino Mega ADK
#else
typedef MAX3421e<P10, P9> MAX3421E; // Official Arduinos (UNO, Duemilanove, Mega, 2560
#endif
It is UsbHost library,, The "Trans" is defined in the sketch, a files that is in sketch folder. I can't find a way to pass the "Trans" to the library ,,
, How to keep "Trans" defined in the different files, and locate in different folder , not in library folder,,[/code]
