How to construct this program
Hello.
I do not have the required knowledge for this task, and I do not know what I am looking for.
The program is supposed to produce a light-show on a LED-matrix. This is an animation that lasts for some seconds.
The Arduino's input is an IR controller.
The IR controller is supposed to change which light-show is displayed, at any moment.
From my knowledge, this means the program either have to constantly check for new inputs, or break out of the loop when a new IR signal is received.
I am currently on my 9th program, but they all end up slow and rough, or non-functional.
I added the base program, from after my knowledge is required.
The IR library uses a Timer2 interrupt, so I assume a timer can't be used again.
/////////////////////////////////////// include //////////////////////////////////////////
#include "IRremote.h"
/////////////////////////////////////// konstanter ///////////////////////////////////////
int receiver = 10; //reciver input
/////////////////////////////////////// objekter /////////////////////////////////////////
IRrecv irrecv(receiver);
decode_results results;
/////////////////////////////////////// setup ////////////////////////////////////////////
void setup(){
  Serial.println("IR Receiver Raw Data + Button Decode Test");
  irrecv.enableIRIn(); // Start the receiver
/////////////////////////////////////// loop /////////////////////////////////////////////
void loop(){
  if (irrecv.decode(&results)) // have we received an IR signal?
  //Serial.println(results.value, HEX);  UN Comment to see raw values
    translateIR();
    irrecv.resume(); // receive the next value
/////////////////////////////////////// translateIR //////////////////////////////////////
void translateIR(){
  switch(results.value){
  case 0xFD10EF:
    Serial.println(" CH-            ");
  case 0xFF629D:
    Serial.println(" CH             ");
  case 0xFD50AF:
    Serial.println(" CH+            ");
  case 0xFF22DD:
    Serial.println(" PREV           ");
  case 0xFF02FD:
    Serial.println(" NEXT           ");
  case 0xFDA05F:
    Serial.println(" PLAY/PAUSE     ");
  case 0xFD906F:
    Serial.println(" VOL-           ");
  case 0xFD807F:
    Serial.println(" VOL+           ");
  case 0xFDB04F:
    Serial.println(" EQ             ");
  case 0xFD30CF:
    Serial.println(" 0              ");
  case 0xFF9867:
    Serial.println(" 100+           ");
  case 0xFFB04F:
    Serial.println(" 200+           ");
  case 0xFD08F7:
    Serial.println(" 1              ");
  case 0xFD8877:
    Serial.println(" 2              ");
  case 0xFD48B7:
    Serial.println(" 3              ");
  case 0xFD28D7:
    Serial.println(" 4              ");
  case 0xFDA857:
    Serial.println(" 5              ");
  case 0xFD6897:
    Serial.println(" 6              ");
  case 0xFD18E7:
    Serial.println(" 7              ");
  case 0xFD9867:
    Serial.println(" 8              ");
  case 0xFD58A7:
    Serial.println(" 9              ");
Have a nice day.
I've not tried the program but from a cursory inspection it's just a decoder. You point the ir transmitter at the receiver and it will display on screen the code being transmitted.
[Yes, its the base program as was explained in the posting!]
You need to store the latest arrived IR message and then use it to select
which LED loop to run in loop().
I'd suggest having a loop function for each LED pattern, and in each loop function
call a common routine to test for a new IR message, and if so record the message
and break out of the loop if its a different one.
MarkT:
The routine called to check for new updates can't do the whole translateIR(); often enough, to pick up a IR signal on the first push of the IR remote. What do you suggest?
Concept is done. Thank you.
int receiver = 10;
byte Kol[4] = {4, 5, 6, 7};
byte Lag[2] = {2, 3};
/////////////////////////////////////// variabler ////////////////////////////////////////
int           SisteIR = 0;
int     TidsVariabel = 60;
int            Teller = 0;
int  TellerVariabel = 100;
void setup(){
/////////////////////////////////////// pinmode //////////////////////////////////////////
  pinMode(Kol[4, 5, 6, 7], OUTPUT);
  pinMode(Lag[2, 3], OUTPUT);
void loop(){
    translateIR();
  VisProgram();
void translateIR(){
  case 0xFD10EF:
    SisteIR = 1;
  case 0xFF629D:
    SisteIR = 2;
  case 0xFD50AF:
    SisteIR = 3;
  case 0xFF22DD:
    SisteIR = 4;
  case 0xFF02FD:
    SisteIR = 5;
  case 0xFDA05F:
    SisteIR = 6;
  case 0xFD906F:
    SisteIR = 7;
    TidsVariabel = TidsVariabel - 10;
  case 0xFD807F:
    SisteIR = 8;
    TidsVariabel = TidsVariabel + 10;
  case 0xFDB04F:
    SisteIR = 9;
  case 0xFD30CF:
    SisteIR = 10;
  case 0xFF9867:
     SisteIR = 11;
  case 0xFFB04F:
    SisteIR = 12;
  case 0xFD08F7:
    SisteIR = 13;
  case 0xFD8877:
    SisteIR = 14;
  case 0xFD48B7:
    SisteIR = 15;
  case 0xFD28D7:
    SisteIR = 16;
  case 0xFDA857:
    SisteIR = 17;
  case 0xFD6897:
    SisteIR = 18;
  case 0xFD18E7:
    SisteIR = 19;
  case 0xFD9867:
    SisteIR = 20;
  case 0xFD58A7:
    SisteIR = 21;
 default:
/////////////////////////////////////// VisProgram ///////////////////////////////////////
void VisProgram(){
  switch(SisteIR){
    case 21:
    Program2();
  case 20:
    Program1();
/////////////////////////////////////// TestIRDelay //////////////////////////////////////
void TestIRDelay(int Teller){
  while(Teller < 100){ // Teller < timer
    if (irrecv.decode(&results)){break;translateIR();}
        Serial.println("hey ho her teller jeg");
        Teller++;
        if (Teller >= 100){break;}
/////////////////////////////////////// Program //////////////////////////////////////////
void Program1(){
    digitalWrite(Lag[0], HIGH);
    digitalWrite(Kol[0], HIGH);
    digitalWrite(Kol[1], HIGH);
    digitalWrite(Kol[2], HIGH);
    digitalWrite(Kol[3], HIGH);
    TestIRDelay(TidsVariabel);
    digitalWrite(Kol[3], LOW);
    digitalWrite(Kol[2], LOW);
    digitalWrite(Kol[1], LOW);
    digitalWrite(Kol[0], LOW);
    digitalWrite(Lag[0], LOW);
void Program2(){
    digitalWrite(Lag[1], HIGH);
    digitalWrite(Lag[1], LOW);
  Serial.println(SisteIR);
  Serial.println(ProgramStadium);
  if(SisteIR == 6){
    if(ProgramStadium = 0){
      Program_1_1();
      translateIR();
      PlussProgramStadium(3);
    else if(ProgramStadium == 1){
      Program_1_2();
      translateIR();
    else if(ProgramStadium == 2){
      Program_1_1();
      translateIR();
    else if(ProgramStadium == 3){
      Program_1_2();
      translateIR();
/////////////////////////////////////// Program_1_1 //////////////////////////////////////
void Program_1_1(){
void Program_1_2(){
void Program_1_3(){
void Program_1_4(){
void PlussProgramStadium(int var){
  if (ProgramStadium >= var){ProgramStadium = 0;}
  else {ProgramStadium++;}
  ProgramValg();
