How to continue loop until condition is met
Hello guys! I just need some help.
I want to continue the loop in my if statement
if(tm.Hour == Hour && tm.Minute == Min && tm.Second == Sec)
    turnon(timeon);
until I get the right range of value of my pHsensor of 7.4-7.6. How can I do that?
Thank you in advance for the help.
#include <Wire.h>
#include <Time.h>
#include <TimeLib.h>
#include <DS1307RTC.h>
#define pump 8
#define Clvalve 9
#define H2Ovalve 10
int Hour=21;
int Min=28;
int Sec=30;
int timeon=60000;
#define pHSensor 0
unsigned long int avgValue;
int buf[10],temp;
#define trig 6
#define echo 7
void turnon(int timeon)
  //First line code of pH
   for(int i=0;i<10;i++)
    buf[i]=analogRead(pHSensor);
    delay(10);
  for(int i=0;i<9;i++)
    for(int j=i+1;j<10;j++)
      if(buf[i]>buf[j])
        temp=buf[i];
        buf[i]=buf[j];
        buf[j]=temp;
  avgValue=0;
  for(int i=2;i<8;i++)
  avgValue+=buf[i];
  float pHValue=(float)avgValue*5.0/1024/6;
  pHValue=3.5*pHValue;
  //last line code of pH
//first line ultrasonic code
  float duration, distance;
  digitalWrite(trig, LOW);
  delayMicroseconds(2);
  digitalWrite(trig, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echo, HIGH);
  distance = (duration/2) *0.0344;
//last line ultrasonic code
  if (pHValue >= 7.4)
    Serial.println("pH Value HIGH!");
    Serial.print("pH:");
    Serial.print(pHValue,2);
    Serial.println("");
    Serial.print("Pump Open!");
    digitalWrite(pump,LOW);
      if (distance >= 12)
        Serial.print("Distance = ");
        Serial.print(distance);
        Serial.println(" cm");
        digitalWrite(pump,HIGH);
        Serial.println("Pump Close!");
        Serial.println("Chlorine Valve Open!");
        digitalWrite(Clvalve, LOW);
        delay(4000);
        digitalWrite(Clvalve, HIGH);
        Serial.println("Chlorine Valve Close!");
        Serial.println("Water Valve Open!");
        digitalWrite(H2Ovalve, LOW);
        delay(4000);
        digitalWrite(H2Ovalve, HIGH);
        Serial.println("Water Valve Close!");
  else if (pHValue <7.4)
    Serial.println("pHValue LOW!");
    Serial.println("");
    Serial.print("Chlorine Valve Open!");
    digitalWrite(Clvalve,LOW);
    delay(4000);
    digitalWrite(Clvalve,HIGH);
    delay(4000);
  while (!Serial);
  pinMode(pump,OUTPUT); // pump for drain =Normally Closed
  pinMode(Clvalve, OUTPUT); // valve of chlorine=Normally closed
  pinMode(H2Ovalve,OUTPUT); //valve of water = Normally closed
  digitalWrite(H2Ovalve,HIGH);
  pinMode(trig, OUTPUT); // ultrasonic sensor
  pinMode(echo, INPUT);
  ultrasonic();
  pHsensor();
  tmElements_t tm;
  if (RTC.read(tm))
    Serial.print("Time = ");
    print2digits(tm.Hour);
    Serial.write(':');
    print2digits(tm.Minute);
    Serial.write(':');
    print2digits(tm.Second);
    Serial.print(", Date = ");
    Serial.print(tm.Day);
    Serial.write('/');
    Serial.print(tm.Month);
    Serial.write('/');
    Serial.print(tmYearToCalendar(tm.Year));
    turnon(timeon);
void pHsensor()
    delay(10);
      if(buf[i]>buf[j])
        temp=buf[i];
        buf[i]=buf[j];
        buf[j]=temp;
  avgValue=0;
  avgValue+=buf[i];
  Serial.print(" pH:");
  Serial.println(" ");
void print2digits(int number) {
  if (number >= 0 && number < 10) {
    Serial.write('0');
  Serial.print(number);
void ultrasonic()
Have you looked up while command?
while (x == 2) {
x ++
makes the mini loop run until x is 2
I've tried the while command but nothing happened when I run the code.
What you’re trying to achieve is that the ‘process’ starts at a given time and ends when the pH has reached a certain value?
If so, you can do this using an additional variable. To give you the idea
  static bool run = false;
  if (tm.Hour == Hour && tm.Minute == Min && tm.Second == Sec)
    run = true;
  if (pH > 7.4 && pH < 7.6)
    run = false;
  if (run == true)
    turnon(timeon);
