How to continuously check the program ?
Hi there, i just started learning arduino and i need help with this program. I managed to make my speed increment work but it looks ugly like hell especially the 30+ checkspeed part . Can anyone help me find a better method?
//Incrementing Motor Speed Control
const int IN1 = 2;
const int IN2 = 3;
const int ENA = 5;
const int but4 = 8;
// motor pins
boolean lastButton = LOW; //Variable containing the previous
//button state
boolean currentButton = LOW; //Variable containing the current
//button state
int speedIncrement = 0;
int buttonState4 = 0; // variable for reading the pushbutton status
pinMode (IN1, OUTPUT);
pinMode (IN2, OUTPUT);
pinMode (ENA, OUTPUT);
pinMode (but4, INPUT_PULLUP); //Set button as an input
  • Debouncing Funtion
  • Pass it the previous button state,
  • and get back the current debounced button state.
    boolean debounce(boolean last)
    boolean current = digitalRead(but4); //Read the button state
    if (last != current) //if it's different
    delay(5); //wait 5ms
    current = digitalRead(but4); //read it again
    return current;
*Motor Speed Selection
*Pass a number for the Motor speed and set it
void setSpeed(int increment)
//speed one
if (increment == 1)
analogWrite(ENA, 110);
Serial.println("b1");
else if (increment == 2)
analogWrite(ENA, 150);
Serial.println("b2");
else if (increment == 3)
analogWrite(ENA, 180);
Serial.println("b3");
else if (increment == 4)
analogWrite(ENA, 200);
Serial.println("b4");
else if (increment == 5)
analogWrite(ENA, 255);
Serial.println("b5");
//OFF
analogWrite(ENA, 0);
Serial.println("b6");
buttonState4 = digitalRead(but4);
if (buttonState4 == LOW) {
Serial.println("0");
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
checkspeed();
delay(100);
checkspeed();
checkspeed();
checkspeed();
checkspeed();
else {
void checkspeed() {
currentButton = debounce(lastButton); //read debounce state
if (lastButton == LOW && currentButton == HIGH) //if it was pressed
speedIncrement++; //Increment motor speedaxzx
lastButton = currentButton; //reset button value
//if cycled through all speed increments
//reset the speed to 0
if (speedIncrement == 6) speedIncrement = 0;
setSpeed(speedIncrement);
checkspeed(); does not need to be called like that.
Since loop repeats over and over, call checkspeed(); once in loop.
Examine how switch/case works.
Use CTRL T to format the sketch.
Please use code tags.
Use the </> icon in the posting menu.
[code] Paste sketch here. [/code]
Hi there sorry about that am new here. if i do checkspeed() only 1 time and i pressed the button it does not go to
else if (increment == 2) and will stuck at if (increment == 1) until i press the button for about 5 times. However when i put the 30+ checkspeed(); then it can work.
To start with, do you know how to use switch/case instead of if/else if
Do you understand what is happening in this section of code?
Note: This sketch is not complete as it stands. (more to follow)
const byte IN1  = 2;
const byte IN2  = 3;
const byte ENA  = 5;
const byte but4 = 8;
const byte heartBeatLED = 13;
//motor pins
byte lastButton     = HIGH;    //Variable containing the previous
//button state
byte currentButton  = HIGH;    //Variable containing the current
byte speedIncrement = 0;
byte buttonState4   = 0;        // variable for reading the pushbutton status
unsigned long currentMillis;
unsigned long heartBeatMillis;
unsigned long lastMillis;
const unsigned long heartBeatDelay = 250UL;
  pinMode (heartBeatLED, OUTPUT);
} //END of      s e t u p ( )
  currentMillis = millis(); //for milli second timing
  //HeartBeat LED, should toggle every heartBeatDelay milliseconds if code is nonblocking
  if (currentMillis - heartBeatMillis >= heartBeatDelay)
    //reset timing
    heartBeatMillis = heartBeatMillis + heartBeatDelay;
    //Toggle heartBeatLED
    digitalWrite(heartBeatLED, !digitalRead(heartBeatLED));
  //check every 50ms
  if (currentMillis - lastMillis >= 50)
    checkspeed();
    //reset timing
    lastMillis = lastMillis + 50;
  //Other nonblocking code
} //END of       l o o p  ( )
xxfuffmxx:
You will have to analyse why a single call of checkSpeed does not work.
