How to control 1 LED with two different Analog inputs
i’m trying to control one LED with two Analog inputs.
so:
If pressure1 & pressure2 are < 20 the RED LED will blink.
and if just pressure1 is < 20 then the RED LED will just be HIGH.
This is the relevant part of my code that i’ve worked on so far just for pressure1 but when i try and add, ‘if pressure2 < 20 ledPinRED blink’ it just doesnt quite work:
  if( pressure1 < 9 )
    {StartMillis = millis ();
    digitalWrite(ledPinGREEN, HIGH);}
  if (millis() - StartMillis >= 2000)
     {digitalWrite(ledPinGREEN,LOW);}
if((9 > pressure1 ) && ( pressure1 < 13.5))
    {StartMillis2 = millis ();}
    if (millis() - StartMillis2 >= 2000)
     {digitalWrite(ledPinAMBER, HIGH);}
      {digitalWrite(ledPinAMBER, LOW);}
if(pressure1 < 20)
    {StartMillis3 = millis ();}
    if (millis() - StartMillis3 >= 2000)
    {digitalWrite(ledPinRED, HIGH);
    {digitalWrite(ledPinRED, LOW);}
Any suggestions as to what is a good approach?
Thanks
You have:
if ((9 > pressure1 ) && ( pressure1 < 13.5))
therefore
if ((pressure1 < 9) && (pressure1 < 13.5))
IF pressure1 is less than 9, it’s also less than 13.5. (Right?)
yes sorry typo, it should be
if ((pressure1 > 9) && (pressure1 < 13.5))
so if pressure 1 is between these two values the AMBER LED will be on.
"Typo" means that you are not (were not) copying your sketch from the IDE and pasting that (between code-tags) here.
