A RAMPS board, which is intended to drive 3D printers, will drive that many steppers.
But you don't say how much power. If it's around 1A then there's lots of drivers. Higher than that is a little unusual for hobbyists so there are fewer to select from.
What is your goal?
Depending on your project goal there are so many controller boards out there.
Aunt Google is your friend with "4 stepper control board" - this will give you a lot of choices.
Then your project goal is the basis for making a buying decision.
But it would be good to know, what you want to do with the steppers. Then we can help you to get one step further.
Thanks, I'm looking out drive steppers to open and close shades. I realize that is still vague because I understand I could open and close those plastic blinds probably with a much weaker motor than I would need for a set of cloth curtains.
Plus I don't really know how I would open a set of cloth curtains, if up-down, diagonal-from-corner or actually slide them completely sideways and back.
Nearly all modern (cheap) steppers are low impedance and cannot be driven from a dual-H-bridge
board, but need chopper dirvers.
You first need to tell us which motors you have, if you haven't chosen motors yet you should
probably start from the beginning and tell us the mechanical details of what you want to drive,
since chosing (and sizing) motors is the first step and we don't know if you know anything about
doing this.
Both of those could be controlled with an A4988 stepper driver - assuming the current figures are 1 amp and 0.4 amps.
The reason I am not sure is because the the data for first motor mentions 1 amp and 2 ohms which imply a voltage of 2v, not 12v. My suspicion is that the 12v figure is wrong. You should check the coil resistance with your multimeter.
Marciokoko:
I have 2 39BYGL215A Stepper Motor - 200 steps/rev
And 1 that just reads Stepper Motor-2ohm
That's what you measured? Normally the same motor is available with many winding options,
so its always wise to stick a multimeter on and confirm the actual phase resistance.
If its 2 ohms you must use a chopper driver. If its 30 ohm (like most of the google search hits
indicate) you'll have to choose between 12V and H-bridges, or 24V and a chopper, or running at
12V from a chopper at lower current/performance.
Why have you chosen stepper motors for this application, it doesn't sounds like a motion-control
project?
