How to control a servo motor using a PID control with input from current sensor. I am not so proficient in arduino and in coding so can anyone please help me. I want to create a closed loop using pid for controlling servo with current sensor acs70331
What have you done so far ?
Can you read the sensor and print the value returned to the Serial monitor ?
Can you convert the sensor value into a range that can be used to control the servo ?
Can you write the converted value to the servo ?
How are you powering the servo ?
I realise that the above questions do not relate to the use of a PID but we have no knowledge of your level of expertise
Have you installed the PID library and looked at the examples it contains ?
