Good morning everyone!
I have the following problem: I am using an Arduino Nano to control a stepper motor through an A4988 driver so that it moves according to some specific rotation protocols. I would like to obtain a motor rotation according to the wave in the figure attached, representing the evolution of the angular position during 1 second. Any suggestions about the code or useful libraries?
You could put a series of positions in an array of positions and send the elements of the array to the stepper. Here is code to illustrate that method. Adjust the stepper speed to accomplish the series in the time that you want.
#include <AccelStepper.h>
const unsigned int NUM_STEPS = 6;
unsigned int xArray[NUM_STEPS] = {0, 3, 65, 40, 65, 10};
const byte enablePin = 8;
AccelStepper stepper(AccelStepper::DRIVER, 2, 5);
pinMode(enablePin, OUTPUT);
digitalWrite(enablePin, LOW);
stepper.setAcceleration(2000);
stepper.setMaxSpeed(200);
stepper.setSpeed(200);
stepper.setCurrentPosition(0);
static unsigned int index = 0;
if (stepper.run() == 0) // stepper stopped. load next position and run
Serial.println(index);
stepper.moveTo(xArray[index]);
index++;
if (index >= NUM_STEPS)
index = 0;
int index = 0 ;
int data [MAX_DATAPOINTS] {.....}
static unsigned long timepoint = 0 ;
stepper.run() ; // YOU MUST CALL THIS OFTEN FOR AccelStepper to work
if (millis() - timepoint > MS_PER_DATAPOINT) // every MS_PER_DATAPOINT milliseconds
timepoint += MS_PER_DATAPOINT ;
if (index < MAX_DATAPOINTS) // wrap index for endless repeat
index = 0 ;
stepper.moveTo (data[index++]) ; // setup new destination
