hey guys i want a little help for my project...........
i want to control 4 servos with 2 joystick module,( with one joystick i want to control 2 servos from each axis)
i made the servo to rotate continuous by using some help from you tube
now i want that if i push the stick up than the servo start rotating and keep rotating until i release the pressure and when i release the pressure from stick the servo should stop immediately and when i push the stick down the servo start rotating in opposite direction (same for other axis with other servo ) , speed doesn't matter for me in this case i just want to use the stick as switches like when i push up it should start rotate clockwise and when i push down it start rotate counter clockwise,
can somebody please help me with the code and connection to the arduino.
thanks in advance..
