I am trying to build a quadcopter using arduino nano v3
I have ESC of 30A
And Brushless motors of 1400Kv
I am a newbie to all this, I need help from starting till the end guys
Please help me
Hi, if your new to Arduino like me I'd suggest looking at some of the basic tutorials first so you get the hang of what it all does and the basic principles. There are lots of videos on YouTube for starters where I spend a lot of my time.
Good luck it sounds an interesting project.
Aside from, as @Langy suggests, learning to crawl before doing the pole vault, an ESC is controlled in the same way a servo is, but has a set up routine that comes with the ESC to set throttle limits. Some also do reverse which is slightly less than desirable in a flying vehicle but required in a car...
Let everything gone above ma head
All the more reason to start from scratch
arjun18:
Successfully writing a program for a quadcopter will not be simple. It is most certainly not a project for someone who does not understand the things that have been said in this Thread.
Anyone with a deep wallet can write an unsuccessful quadcopter program.
Buy an Arduino Uno and learn how to program it. When you are confident about programming and when you can understand th advice here then it will be time to consider your quadcopter project.
...R
