how to control motor with wheel encoder and photo sensor
guys i need to know how the photos sensor is used along with arduino to position control a motor !! can someone explain me with a example code !!
for you to understand my exact requirement ! just get the perspective of a working printer with photo sensors and wheel encoder !! i want this type !! but have no idea of how to interface the photo sensor and wheel encoder with arduino to control the motor ! im using arduino uno and nano
thank you
Which photo sensor?
Is your ! key broken?
the photo interrupter sensors which is used in printers !
Basically there are three parts:
1) reading the sensor and maintaining a variable with the current count. 2) code that drive the motor forwards or backwards in proportion to a signed error signal 3) a feedback loop (such as PID controller) mapping error in position to motor drive signal
Here’s the OP’s pic inline!!!
MarkT yes i can understand the algorithm ! but im not okay with the code !! can some one explain me this with an example code
What code?
The interrupter will read as a HIGH or a LOW on a digital on, depending on how it is wired. How you treat that HIGH or LOW depends on you.
(Please, turn your keyboard over and give it a shake - that sticking ! key is starting to get irritating)
