How to control my triac ?
Hello, I have made an electric card and I would like to dimm my lamps but any programm I load into the arduino Nano works.
I took the code on the playground site:
// AC Control V1.1
// This Arduino sketch is for use with the heater
// control circuit board which includes a zero
// crossing detect function and an opto-isolated TRIAC.
// AC Phase control is accomplished using the internal
// hardware timer1 in the Arduino
// Timing Sequence
// * timer is set up but disabled
// * zero crossing detected on pin 2
// * timer starts counting from zero
// * comparator set to "delay to on" value
// * counter reaches comparator value
// * comparator ISR turns on TRIAC gate
// * counter set to overflow - pulse width
// * counter reaches overflow
// * overflow ISR turns off TRIAC gate
// * TRIAC stops conducting at next zero cross
// The hardware timer runs at 16MHz. Using a
// divide by 256 on the counter each count is
// 16 microseconds.  1/2 wave of a 60Hz AC signal
// is about 520 counts (8,333 microseconds).
#include <avr/io.h>
#include <avr/interrupt.h>
#define DETECT 2  //zero cross detect
#define GATE 9    //TRIAC gate
#define PULSE 4   //trigger pulse width (counts)
int i=483;
void setup(){
  // set up pins
  pinMode(DETECT, INPUT);     //zero cross detect
  digitalWrite(DETECT, HIGH); //enable pull-up resistor
  pinMode(GATE, OUTPUT);      //TRIAC gate control
  // set up Timer1
  //(see ATMEGA 328 data sheet pg 134 for more details)
  OCR1A = 100;      //initialize the comparator
  TIMSK1 = 0x03;    //enable comparator A and overflow interrupts
  TCCR1A = 0x00;    //timer control registers set for
  TCCR1B = 0x00;    //normal operation, timer disabled
  // set up zero crossing interrupt
  attachInterrupt(0,zeroCrossingInterrupt, RISING);
    //IRQ0 is pin 2. Call zeroCrossingInterrupt
    //on rising signal
//Interrupt Service Routines
void zeroCrossingInterrupt(){ //zero cross detect
  TCCR1B=0x04; //start timer with divide by 256 input
  TCNT1 = 0;   //reset timer - count from zero
ISR(TIMER1_COMPA_vect){ //comparator match
  digitalWrite(GATE,HIGH);  //set TRIAC gate to high
  TCNT1 = 65536-PULSE;      //trigger pulse width
ISR(TIMER1_OVF_vect){ //timer1 overflow
  digitalWrite(GATE,LOW); //turn off TRIAC gate
  TCCR1B = 0x00;          //disable timer stopd unintended triggers
void loop(){ // sample code to exercise the circuit
i--;
OCR1A = i;     //set the compare register brightness desired.
if (i<65){i=483;}
delay(15);
with the schema below in the joined piece.
What is wrong ?
Once you gate the triac you no longer need to drive the gate. You should be able to eliminate the second ISR. To be sure you give it enough time to fire simply write the gate pin several times, this does nothing but use a small amount of time. I do not see where you are getting the zero cross information in your schematic, that takes a second opto coupler designed for this type of application.This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
Hi, the zero cross information come from before the tension is redressed, see the green arrow on the picture.
I wonder if my schema is good, especially for th zero cross detection...
