@Robin2 Posted the link to the data sheet for the stepper motor in the first post of this thread.
What electronics do I need? I don't tinker with electronics usually, so I am really a beginner. If you can give me a step by step tutorial, then I can follow it. Appreciate any help!
Sorry, when it was not an active link I missed that.
The motor seems to need 1.5 amps so a Pololu DRV8825 or A4988 or a SparkFun BigEasydriver should be suitable. I have no connection with them but I would choose the DRV8825 and the Pololu website has good data about wiring and usage.
You also need a suitable power supply for the motor. Any voltage from (say) 12v up to the limit of the driver should be suitable. If you need high speed you need the higher voltage.
Make sure to adjust the driver so that it matches the current required by your motor or the smoke may escape.
What speeds are you talking about? Please note that if you want REALLY low speeds and smooth rotations, a stepper motor might not be the best choice. Even the 32x microstepping of the DRV8825 doesn't allow you to have smooth transitions between each full-step at low speeds.
If you want it to be smooth, you should consider some further components.
