How to control one rgb led with TLC5940
Hello
I am going to make an project where i have to control 21 rgb leds. 16 of them is in pair and the other ones is separate. The thing is that i cant figure how to control one ore two only. The examples for tlc5940 works good, but i don't want a christmas tree.
For example i want led nr1 and 8 (channel (1-3) and (24-27) ) to be green.
wait 5 sec and then light up 2 other leds in one other color.
Arduino Tlc5940 Library Documentation
http://alex.kathack.com/codes/tlc5940arduino/html_r014/index.html
Live long!
Okey sorry! The thing is that i am not good at this programming stuff :slight_smile: , i am usually "back engineering" the code trying to understand what are doing what and then make it to work somehow.. but this example code don't have any basic stuff like turn one led on, there is a servo library for it to but i don't get the thing..
This is what i have tried, i believed it was just to give the channel a value and then use delay for on time :).
#include "Tlc5940.h"
Tlc.init();
Tlc.update();
Tlc.set (1, 2000);
Tlc.set (2, 0);
Tlc.set (3, 1000);
Tlc.clear();
    A simple 1-d oscilliscope: scan all the channels, setting the PWM output
    value to 4x the analog pin 0 value (0 - 1024 * 4 = 4096).  The value will
    fade to zero as the channels keep scanning.
    See the BasicUse example for hardware setup.
    Alex Leone <acleone ~AT~ gmail.com>, 2009-02-03 */
#include "tlc_fades.h"
// which analog pin to use
#define ANALOG_PIN      0
// how many millis to strobe over all the LEDs
#define SCOPE_PERIOD    (500 * NUM_TLCS)
#define LED_PERIOD      SCOPE_PERIOD / (NUM_TLCS * 16)
TLC_CHANNEL_TYPE channel;
  Tlc.init();
  uint32_t lastMillis = millis();
  tlc_addFade(channel,                      // led channel
              analogRead(ANALOG_PIN) * 4,   // start fade value (0-4095)
              0,                            // end fade value (0-4095)
              lastMillis + 2,               // start millis
              lastMillis + (uint16_t)SCOPE_PERIOD / 4  // end millis
  if (channel++ == NUM_TLCS * 16) {
    channel = 0;
  uint32_t currentMillis;
  do {
    currentMillis = millis();
    tlc_updateFades(currentMillis);
  } while (currentMillis - lastMillis <= LED_PERIOD);
(code tags added by moderator - please use them in the future)
   Basic Pin setup:
   ------------                                  ---u----
   ARDUINO   13|-> SCLK (pin 25)           OUT1 |1     28| OUT channel 0
             12|                           OUT2 |2     27|-> GND (VPRG)
             11|-> SIN (pin 26)            OUT3 |3     26|-> SIN (pin 11)
             10|-> BLANK (pin 23)          OUT4 |4     25|-> SCLK (pin 13)
              9|-> XLAT (pin 24)             .  |5     24|-> XLAT (pin 9)
              8|                             .  |6     23|-> BLANK (pin 10)
              7|                             .  |7     22|-> GND
              6|                             .  |8     21|-> VCC (+5V)
              5|                             .  |9     20|-> 2K Resistor -> GND
              4|                             .  |10    19|-> +5V (DCPRG)
              3|-> GSCLK (pin 18)            .  |11    18|-> GSCLK (pin 3)
              2|                             .  |12    17|-> SOUT
              1|                             .  |13    16|-> XERR
              0|                           OUT14|14    15| OUT channel 15
   -  Put the longer leg (anode) of the LEDs in the +5V and the shorter leg
        (cathode) in OUT(0-15).
   -  +5V from Arduino -> TLC pin 21 and 19     (VCC and DCPRG)
   -  GND from Arduino -> TLC pin 22 and 27     (GND and VPRG)
   -  digital 3        -> TLC pin 18            (GSCLK)
   -  digital 9        -> TLC pin 24            (XLAT)
   -  digital 10       -> TLC pin 23            (BLANK)
   -  digital 11       -> TLC pin 26            (SIN)
   -  digital 13       -> TLC pin 25            (SCLK)
   -  The 2K resistor between TLC pin 20 and GND will let ~20mA through each
      LED.  To be precise, it's I = 39.06 / R (in ohms).  This doesn't depend
      on the LED driving voltage.
   - (Optional): put a pull-up resistor (~10k) between +5V and BLANK so that
                 all the LEDs will turn off when the Arduino is reset.
   If you are daisy-chaining more than one TLC, connect the SOUT of the first
   TLC to the SIN of the next.  All the other pins should just be connected
   together:
       BLANK on Arduino -> BLANK of TLC1 -> BLANK of TLC2 -> ...
       XLAT on Arduino  -> XLAT of TLC1  -> XLAT of TLC2  -> ...
   The one exception is that each TLC needs it's own resistor between pin 20
   and GND.
   This library uses the PWM output ability of digital pins 3, 9, 10, and 11.
   Do not use analogWrite(...) on these pins.
   This sketch does the Knight Rider strobe across a line of LEDs.
 /* Call Tlc.init() to setup the tlc.
    You can optionally pass an initial PWM value (0 - 4095) for all channels.*/
 Tlc.init();
/* This loop will create a Knight Rider-like effect if you have LEDs plugged
  into all the TLC outputs.  NUM_TLCS is defined in "tlc_config.h" in the
  library folder.  After editing tlc_config.h for your setup, delete the
  Tlc5940.o file to save the changes. */
 int direction = 1;
 for (int channel = 0; channel < NUM_TLCS * 16; channel += direction) {
   /* Tlc.clear() sets all the grayscale values to zero, but does not send
      them to the TLCs.  To actually send the data, call Tlc.update() */
   Tlc.clear();
   /* Tlc.set(channel (0-15), value (0-4095)) sets the grayscale value for
      one channel (15 is OUT15 on the first TLC, if multiple TLCs are daisy-
      chained, then channel = 16 would be OUT0 of the second TLC, etc.).
      value goes from off (0) to always on (4095).
      Like Tlc.clear(), this function only sets up the data, Tlc.update()
      will send the data. */
   if (channel == 0) {
     direction = 1;
     Tlc.set(channel - 1, 1000);
   Tlc.set(channel, 4095);
   if (channel != NUM_TLCS * 16 - 1) {
     Tlc.set(channel + 1, 1000);
     direction = -1;
   /* Tlc.update() sends the data to the TLCs.  This is when the LEDs will
      actually change. */
   Tlc.update();
   delay(75);
Sorry for bumping this once more but i am stuck. I have been on every single site google have given me, and i can't find any example to just control a few leds at a time whit the tlc5940.
This is going to be an fun project, all the stuff is on place and i only have to do the coding to finish it up. :confused:
I am so sorry Delta_G i had to unplug the power to make it work. Thx for your help! :slight_smile:
this litle step to just make an led glow in that color i want will make an big differens for mankind!
Live long Delta!
