How to control several bluetooth module in the same time?
Hello!
I need to control three bluetooth module with my phone, how can I do it?
this seems to be a phone (which one, we don't know) question...
In my opinion You need 3 BT channels in the phone.
or round robin.
Depends which device is master and which is slave too and what type of BT (BLE ?) is at the back of this
So there are ways to pair and unpair BT connections on the fly?
The master can decide where to connect (AT+BIND for example on a common HC-05). As long as the other device accepts then you are connected.
Probably more a phone problem than an Arduino problem, or alternatively, you don't, you have a master Arduino that controls the others, and it alone talks to the phone. The above also assumes you have good reason for not using WiFI, which is likely to be a better solution.
Thank you for all your answers!
Finally, I think I will create a remote for my project, it's a better idea.
Do you know how to have the RSSI of a bluetooth module? I'd seen there is the method rssi() but it's working on the most part of bluetooth module?
Yes, there's the question.
Why? Just why!
Imagine you want to control several things with your phone like your lights, your garage door, or other.
