How to control the pins in Arduino Nano?
Helo,
I've got a question.
I own this board: https://www.amazon.de/dp/B01NBS2UBL/ref=pe_3044161_189395811_TE_SCE_dp_4
Now I installed Arduino IDE.
This is my program and it works fine:
const int A = 1;
int i = 1000;
bool plusorminus = true;
  pinMode(A, OUTPUT);
  if(plusorminus == true) i = i - 100;
  else i = i + 100;
  digitalWrite(A, HIGH);
  delay(i);
  digitalWrite(A, LOW);
  delay(i);
  if(plusorminus == true && i == 0) plusorminus = false;
  else if(plusorminus == false && i == 1000) plusorminus = true;
Now, I want to blink my LED on a different PIN. How is the configuration of the PINs on this board? I can't figure it out. When I use for example A = 4 (PIN 4), then I can't find the PIN on the board to blink my LED.
This is my first problem.
My second is, that I own the book "Make: AVR Programming". There is a code sample like this:
#include <avr/io.h>
#include <util/delay.h>
int main(void) {
  DDRB = 0b00000001;
  while(1) {
    PORTB = 0b00000001;
    _delay_ms(1000);
    PORTB = 0b00000000;
   _delay_ms(1000);
  return (0);
This does compile. But when I load it to the board, it does nothing... Why?
Thank you for every answer! :slight_smile:
Because you have not called init() to make the hardware ready.
Could it be the digital pin cunningly labelled D4, do you think ?
The pin numbers printed on the board do not relate directly to the pin numbers of the AVR chip. They are automatically translated as part of the compilation process
UKHeliBob:
No, it isn't. :frowning: When I try to plug the LED to PIN D4, then it doesn't blink.
PaulS:
#include <avr/io.h>
int main(void) {
  init();
  DDRB = 0b00000001;
  while (1) {
    PORTB = 0b00000001;
    _delay_ms(1000);
    PORTB = 0b00000000;
    _delay_ms(1000);
  return (0);
This doesn't work also. The LED doesn't blink, I tried to connect every pin with the LED...
What only works is, if I set A = 1, then the PIN "TX1" is blinking. And when I set A = 3, then "D3" is blinking.
No matter, how I can control the other PINs... It starts then with A = 18 or somehow...
Are you saying that if you set A = 4 in the first sketch of your original post and connect an LED (and resistor, of course) to D4 that the LED does not blink ?
What happens if you set A = LED_BUILTIN ?
Does the built in LED on pin 13 blink ?
This thread is a good example of why it's a crap idea to ask two questions at once.
UKHeliBob:
Yes, when I set A = 4 then D4 doesn't blink.
This works:
const int A = LED_BUILTIN;
What voltage do you get from D4 if you set it's state permanently HIGH ?
UKHeliBob:
About 0.4 V with HIGH and 0.4 V with LOW...
ubik123:
It sounds like the board is busted
Hm. I've got two boards and yes, it looks like it is defect.
Are there any advices to NOT destroy the board? :slight_smile: (I'm a newbie)
Well, the only thing what I did is to try every pin. So i connected my LED step by step to every pin. But I think it wasn't a good idea. How can I prevent this?
What value of current limiting resistor did you use ?
UKHeliBob:
I'm going to guess that the answer to that is "what resistor? What are you talking about?".
PaulS:
I agree. That's why I framed the question in your the way I did
Or, the answer could be "What resistors? I use these."
UKHeliBob:
240 Ohm. The LED is a green one.
