How to control the velocity of a servo motor using a potentiometer ?
I'm running a sketch for a ClearPath SDSK servo motor turning forward and backwards. I can change the velocity, forward/backwards step manually, but I would like to use a potentiometer to do that on the fly.
The purpose for that is a ventilator pump I'm building. I found some sketches on "using potentiometer" but I'm having problems integrating it into my loop routine. Any help is greatly appreciate.
Thanks
here is the link to the sketch:
If you are using a delay, as in the sweep example, to control the servo movement speed, then maybe set the delay as a variable that is changed by the pot
How are you changing speed manually? What is minimum and maximum speed?
OP's code:
  SingleAxisDemo
  Runs a Teknic ClearPath SDSK or SDHP motor, back and forth
 This example code is in the public domain.
//Import Required libraries
#include <ClearPathMotorSD.h>
#include <ClearPathStepGen.h>
// initialize a ClearPathMotorSD Motor
ClearPathMotorSD X;
//initialize the controller and pass the reference to the motor we are controlling
ClearPathStepGen machine(&X);
// the setup routine runs once when you press reset:
  //Begin Serial Communication // NOTE: If communication lags, consider increasing baud rate
//X.attach(9);                //attach motor so Step/B is connected to pin 9
//X.attach(8,9);              //Direction/A is pin 8, Step/B is pin 9
//X.attach(8,9,6);            //Direction/A is pin 8, Step/B is pin 9, Enable is pin 6
X.attach(8,9,6,4);          //Direction/A is pin 8, Step/B is pin 9, Enable is pin 6, HLFB is pin 4
// Set max Velocity.  Parameter can be between 2 and 100,000 steps/sec
  X.setMaxVel(100000);
// Set max Acceleration.  Parameter can be between 4000 and 2,000,000 steps/sec/sec
  X.setMaxAccel(2000000);
// Enable motor, reset the motor position to 0
X.enable();
delay(100);
// Set up the ISR to constantly update motor position.  All motor(s) must be attached, and enabled before this function is called.
machine.Start();
// the loop routine runs over and over again forever:
 // Move the motor forward 10,000 steps
   X.move(10000);
   Serial.println("Move Start");
// wait until the command is finished and The motor's HLFB asserts
   while(!X.commandDone()||!X.readHLFB()) //just use command done if not using motor feedback
   Serial.println("Move Done");
// Move the motor backwards 10,000 steps
   X.move(-10000);
   Serial.println("Negative Move Begins");
To change the speed manually, I change the velocity in the sketch. same for forwards and backwards move.
The range for the max Velocity is between 500-25000 steps/sec. and and 500-9000 steps/sec for forward and backwards move.
