Hello guys, this is my code:
#define A0 27.5
#define AS0 29.1
#define B0 30.8
#define C1 32.7
#define CS1 34.6
#define D1 36.7
#define DS1 38.8
#define E1 41.2
#define F1 43.6
#define FS1 46.2
#define G1 49
#define GS1 51.9
#define A1 55
#define AS1 58.3
#define B1 61.7
#define C2 65.4
#define CS2 69.2
#define D2 73.4
#define DS2 77.8
#define E2 82.4
#define F2 87.3
#define FS2 92.5
#define G2 98
#define GS2 103.8
#define A2 110
#define AS2 116.5
#define B2 123.5
#define C3 130.8
#define CS3 138.6
#define D3 146.8
#define DS3 155.6
#define E3 164.8
#define F3 174.6
#define FS3 185
#define G3 196
#define GS3 207.7
#define A3 220
#define AS3 233.1
#define B3 246.9
#define C4 261.6
#define CS4 277.2
#define D4 293.7
#define DS4 311.1
#define E4 329.6
#define F4 349.2
#define FS4 370
#define G4 392
#define GS4 415.3
#define A4 440
#define AS4 466.2
#define B4 493.9
#define C5 523.3
#define CS5 554.4
#define D5 587.3
#define DS5 622.3
#define E5 659.3
#define F5 698.5
#define FS5 740
#define G5 784
#define GS5 830.6
#define A5 880
#define AS5 932.3
#define B5 987.8
#define C6 1046.5
#define CS6 1108.7
#define D6 1174.7
#define DS6 1244.5
#define E6 1318.5
#define F6 1396.9
#define FS6 1480
#define G6 1568
#define GS6 1661.2
#define A6 1760
#define AS6 1864.7
#define B6 1975.5
#define C7 2093
#define CS7 2217.5
#define D7 2349.3
#define DS7 2489
#define E7 2637
#define F7 2793.8
#define FS7 2960
#define G7 3136
#define GS7 3322.4
#define A7 3520
#define AS7 3729.3
#define B7 3951.1
#define C8 4186
const int buzzerPin = 9;
const int buttonPin = 10;
const int melody[] = {F6, A6, E6, D6, AS4, F5, A5, E5, D5, 0, D7};
const int noteDurations[] = {2, 2, 4, 8, 8, 2, 2, 4, 4, 4, 7};
const int tempo = 150;
const int volume = 256;
void setup(){
pinMode(buzzerPin, OUTPUT);
pinMode(buttonPin, INPUT);
void loop(){
boolean buttonState = digitalRead(buttonPin);
if(buttonState == LOW){
for(int thisNote = 0; thisNote <= 10; thisNote++){
int noteDuration = noteDurations[thisNote] * 60000/tempo;
int i;
if(melody[i] != 0){
for(i = 0; i <= melody[i]*noteDuration/1000; i++){
analogWrite(buzzerPin, volume);
delayMicroseconds(500000/melody[i]);
analogWrite(buzzerPin, 0);
else{
noTone(buzzerPin);
delay(noteDuration);
noTone(buzzerPin);
else{
noTone(buzzerPin);
When I press the button, the buzzer makes a cracking sound. I understand it's because of the delayMicroseconds() for loop, but I used that as a replacement for the tone() function. I wanted to know how to control the volume while using the tone() function in PWM pins. I appreciate any solutions to this
And I know I could've just used a resistor, but if I need to modify this code, I would like some notes louder than others.
Your duplicate post has been deleted
UKHeliBob:
I'm sorry, I sort of had a connection error so it didn't save. So I copied it and posted it again and I didn't think it was duplicate
look at the top or bottom of the thread. There is a box "NO ALERTS OR EMAILS". Click that and set for the options you wish.
Paul
Don't the "A0", "B0", "A1" etc definitions cause compilation problems?
It compiled just fine for me. But when I uploaded it, it didn't work as what I wished.
int i;
if(melody[i] != 0){
Hmmm
TheMemberFormerlyKnownAsAWOL:
int i;
if(melody[i] != 0){
Hmmm
Okay, that means the 0 symbolizes for NO sound. So if it's not equal to 0, it plays the sound. If it is, that's noTone();
I wasn't interested in the zero.
I was interested in i
i indicates one of the entries in melody[].
And what is its value?
Oh, I get it! I'm supposed to use a different variable for the for() loop so it doesn't infere. However my problem isn't fixed. It still doesn't work
#define A0 27.5
#define AS0 29.1
#define B0 30.8
#define C1 32.7
#define CS1 34.6
#define D1 36.7
#define DS1 38.8
#define E1 41.2
#define F1 43.6
#define FS1 46.2
#define G1 49
#define GS1 51.9
#define A1 55
#define AS1 58.3
#define B1 61.7
#define C2 65.4
#define CS2 69.2
#define D2 73.4
#define DS2 77.8
#define E2 82.4
#define F2 87.3
#define FS2 92.5
#define G2 98
#define GS2 103.8
#define A2 110
#define AS2 116.5
#define B2 123.5
#define C3 130.8
#define CS3 138.6
#define D3 146.8
#define DS3 155.6
#define E3 164.8
#define F3 174.6
#define FS3 185
#define G3 196
#define GS3 207.7
#define A3 220
#define AS3 233.1
#define B3 246.9
#define C4 261.6
#define CS4 277.2
#define D4 293.7
#define DS4 311.1
#define E4 329.6
#define F4 349.2
#define FS4 370
#define G4 392
#define GS4 415.3
#define A4 440
#define AS4 466.2
#define B4 493.9
#define C5 523.3
#define CS5 554.4
#define D5 587.3
#define DS5 622.3
#define E5 659.3
#define F5 698.5
#define FS5 740
#define G5 784
#define GS5 830.6
#define A5 880
#define AS5 932.3
#define B5 987.8
#define C6 1046.5
#define CS6 1108.7
#define D6 1174.7
#define DS6 1244.5
#define E6 1318.5
#define F6 1396.9
#define FS6 1480
#define G6 1568
#define GS6 1661.2
#define A6 1760
#define AS6 1864.7
#define B6 1975.5
#define C7 2093
#define CS7 2217.5
#define D7 2349.3
#define DS7 2489
#define E7 2637
#define F7 2793.8
#define FS7 2960
#define G7 3136
#define GS7 3322.4
#define A7 3520
#define AS7 3729.3
#define B7 3951.1
#define C8 4186
const int volume = 500;
void setup(){
void loop(){
int i;
if(melody[i] != 0){
for(int x = 0; x <= melody[i]*noteDuration/1000; x++){
else{
noTone(buzzerPin);
noTone(buzzerPin);
else{
noTone(buzzerPin);
This is my new code. (Which still fails).
int i;
if(melody[i] != 0){
We've been here before.
Okay, I wanted to just ask how to use the tone() function while controlling the volume of the piezo buzzer on a PWM analog output pin.
J-M-L
December 29, 2020, 10:47pm
17
To your question, read this
As far as i is concerned in
int i;
if(melody[i] != 0){...
the question remains. You declare a local variable i without assigning any value to it and you then use it. What index do you think will be used in the comparison?
J-M-L:
int i;
I used "thisNote" instead. I got it, but still not working Also, I didn't say I wanted to adjust the volume of the entire thing, just on specific notes. To do that, I will need to modify the code. Does anyone know how?
pon00009:
No, still not understanding this.
Code please.
Code please.
Okay...
#define A0 27.5
#define AS0 29.1
#define B0 30.8
#define C1 32.7
#define CS1 34.6
#define D1 36.7
#define DS1 38.8
#define E1 41.2
#define F1 43.6
#define FS1 46.2
#define G1 49
#define GS1 51.9
#define A1 55
#define AS1 58.3
#define B1 61.7
#define C2 65.4
#define CS2 69.2
#define D2 73.4
#define DS2 77.8
#define E2 82.4
#define F2 87.3
#define FS2 92.5
#define G2 98
#define GS2 103.8
#define A2 110
#define AS2 116.5
#define B2 123.5
#define C3 130.8
#define CS3 138.6
#define D3 146.8
#define DS3 155.6
#define E3 164.8
#define F3 174.6
#define FS3 185
#define G3 196
#define GS3 207.7
#define A3 220
#define AS3 233.1
#define B3 246.9
#define C4 261.6
#define CS4 277.2
#define D4 293.7
#define DS4 311.1
#define E4 329.6
#define F4 349.2
#define FS4 370
#define G4 392
#define GS4 415.3
#define A4 440
#define AS4 466.2
#define B4 493.9
#define C5 523.3
#define CS5 554.4
#define D5 587.3
#define DS5 622.3
#define E5 659.3
#define F5 698.5
#define FS5 740
#define G5 784
#define GS5 830.6
#define A5 880
#define AS5 932.3
#define B5 987.8
#define C6 1046.5
#define CS6 1108.7
#define D6 1174.7
#define DS6 1244.5
#define E6 1318.5
#define F6 1396.9
#define FS6 1480
#define G6 1568
#define GS6 1661.2
#define A6 1760
#define AS6 1864.7
#define B6 1975.5
#define C7 2093
#define CS7 2217.5
#define D7 2349.3
#define DS7 2489
#define E7 2637
#define F7 2793.8
#define FS7 2960
#define G7 3136
#define GS7 3322.4
#define A7 3520
#define AS7 3729.3
#define B7 3951.1
#define C8 4186
void setup(){
void loop(){
if(melody[thisNote] != 0){
tone(buzzerPin, melody[thisNote], noteDuration);
else{
noTone(buzzerPin);
noTone(buzzerPin);
else{
noTone(buzzerPin);
