What statement or function should i use to control the program in the loop?
My goal is to start the program from the time the microcontroller is on after 7 mins the program inside the void loop (MULTIPLE LED ON and OFF) will run for 1 min then after 1 min is finished the program in the void loop will stop. and then again after 7 mins the void loop program will run again for 1 min. and again and again.
Thanks in advance.
int ledPin1 = 27; // LED 1 connected to digital pin 27
int ledPin2 = 26; // LED 2 connected to digital pin 26
int ledPin3 = 25; // LED 3 connected to digital pin 25
int ledPin4 = 14; // LED 4 connected to digital pin 14
int ledPin5 = 13; // LED 5 connected to digital pin 13
int ledPin6 = 12; // LED 6 connected to digital pin 12
int ledState1 = LOW; // LED 1 is initially set to off
int ledState2 = HIGH; // LED 2 is initially set to off
int ledState3 = LOW; // LED 3 is initially set to off
int ledState4 = LOW; // LED 4 is initially set to off
int ledState5 = LOW; // LED 5 is initially set to off
int ledState6 = LOW; // LED 6 is initially set to off
unsigned long millis1; // initialises millis marker for LED 1
unsigned long millis2; // initialises millis marker for LED 2
unsigned long millis3; // initialises millis marker for LED 3
unsigned long millis4; // initialises millis marker for LED 4
unsigned long millis5; // initialises millis marker for LED 5
unsigned long millis6; // initialises millis marker for LED 6
pinMode(ledPin1, OUTPUT); // sets the digital pin as output
pinMode(ledPin2, OUTPUT); // sets the digital pin as output
pinMode(ledPin3, OUTPUT); // sets the digital pin as output
pinMode(ledPin4, OUTPUT); // sets the digital pin as output
pinMode(ledPin5, OUTPUT); // sets the digital pin as output
pinMode(ledPin6, OUTPUT); // sets the digital pin as output
// Update LED States
digitalWrite(ledPin1, ledState1);
digitalWrite(ledPin2, ledState2);
digitalWrite(ledPin3, ledState3);
digitalWrite(ledPin4, ledState4);
digitalWrite(ledPin5, ledState5);
digitalWrite(ledPin6, ledState6);
// Toggle the LED states if the duration has passed
// LED -1
if ( (millis() - millis1) > 2000) {
millis1 = millis();
if (ledState1 == LOW) {
ledState1 = HIGH;
} else if (ledState1 == HIGH) {
ledState1 = LOW;
// LED -2
if ( (millis() - millis2) > 2000) {
millis2 = millis();
if (ledState2 == LOW) {
ledState2 = HIGH;
} else if (ledState2 == HIGH) {
ledState2 = LOW;
// LED -3
if ( (millis() - millis3) > 1500) {
millis3 = millis();
if (ledState3 == LOW) {
ledState3 = HIGH;
} else if (ledState3 == HIGH) {
ledState3 = LOW;
// LED -4
if ( (millis() - millis4) > 3000) {
millis4 = millis();
if (ledState4 == LOW) {
ledState4 = HIGH;
} else if (ledState4 == HIGH) {
ledState4 = LOW;
// LED -5
if ( (millis() - millis5) > 6000) {
millis5 = millis();
if (ledState5 == LOW) {
ledState5 = HIGH;
} else if (ledState5 == HIGH) {
ledState5 = LOW;
// LED -6
if ( (millis() - millis6) > 2500) {
millis6 = millis();
if (ledState6 == LOW) {
ledState6 = HIGH;
} else if (ledState6 == HIGH) {
ledState6 = LOW;
