Farel
August 5, 2015, 1:12am
1
Hi guys,
I need a help to control two servo motors one by one. Currently i only managed to work on two servo motors working at the same time as below coding. Can someone help me how to control servo motors one by one? For example, i want only my left servo rotates 90 degree first then stop. Then my right servo motor rotates 45 degree while the left servo motor remains static. Thank you.
#include <Servo.h>
Servo servoLeft; // Define left servo
Servo servoRight; // Define right servo
servoLeft.attach(10); // Set left servo to digital pin 10
servoRight.attach(9); // Set right servo to digital pin 9
void loop() { // Loop through motion tests
forward(); // Example: move forward
delay(2000); // Wait 2000 milliseconds (2 seconds)
reverse();
delay(2000);
turnRight();
delay(2000);
turnLeft();
delay(2000);
stopRobot();
delay(2000);
// Motion routines for forward, reverse, turns, and stop
void forward() {
servoLeft.write(0);
servoRight.write(180);
void reverse() {
servoLeft.write(180);
servoRight.write(0);
void turnRight() {
void turnLeft() {
servoLeft.write(0);
void stopRobot() {
servoLeft.write(90);
servoRight.write(90);
Robin2
August 5, 2015, 9:05am
2
Farel:
I wonder if your problem is the need to wait for the first servo to finish moving before you instruct the second servo to move.
You cannot tell when a servo has reached its destination. All you can do is wait a suitable amount of time. For example
myServoA.write(90);
delay(300);
myServoB.write(35);
However it would probably be a good idea not to use delay() for timing. Instead use millis() as illustrated in several things at a time .
...R
I can't see in your code where you instruct the servos to move one at a time!! I am working on a servo robot too.
Here's my code it might help??
Regards
Mel.
int Aspeed,Bspeed,speed,Halt=90,center=90; // motor speeds
int FRQ,TD;
float cm,A,B,distance;
Servo servoLeft,servoRight,servoScan; // create servo object/s to control the servo/s
servoLeft.attach(2); // attaches the servo/motor on pin 11
servoRight.attach(3); // attaches the servo/motor on pin 12
servoScan.attach(4); // U/S distance scanner.
servoLeft.write(90); // Stop motors from running
servoRight.write(90); // Stop command
delay(300);
pinMode(13, OUTPUT);
for (int i=0; i <= 5000; i++)
sound(i,40);
scan();
delay(3000);
distance=scanner(cm);
if(distance <=18)
Radar();
if(distance >10)
forward(45);
void stop()
void forward(int Aspeed)
servoLeft.write(Aspeed);
speed=Halt-Aspeed;
Bspeed=Halt+speed;
servoRight.write(Bspeed);
void backward(int Aspeed)
speed=Halt-Aspeed;
Bspeed=Halt+speed;
void turn(int Aspeed)
servoRight.write(Aspeed);
void scan()
servoScan.write(90);
for (int i=0; i <= 180; i++)
servoScan.write(i);
delay(20);
for (int i=180; i >= 0; i--)
servoScan.write(i);
delay(20);
delay(1500);
void sound(int FRQ,int TD)
tone(13,FRQ,TD);
void Radar()
stop();
delay(200);
backward(85);
stop();
servoScan.write(0);
sound(2200,20);
A=scanner(cm);
delay(100);
servoScan.write(180);
sound(2200,20);
B=scanner(cm);
delay(100);
delay(100);
if (A>B)
turn(150); //Then turn left
delay(300);
turn(30); //Then turn right
delay(300);
long scanner(long cm)
const int pingPin=7, EchoPin=8;
long duration;
// The SRF005 is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse before to ensure a clean HIGH pulse:
pinMode(pingPin, OUTPUT);
pinMode(EchoPin, INPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
duration = pulseIn(EchoPin, HIGH);
delay(100);
// convert the time into a distance
// inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
return (cm);
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimetre.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
