i have an ADC i am using and i want to calibrate it
reading the adc i use this function to get me the voltage reading
double toVoltage (uint32_t val, double referenceVoltage)
return (double)(val*referenceVoltage/8388607);
now with the voltage reading i am able to calculate the offset and let us say that offset value is 0.0007 volts
how do i convert this back to 16 bits twos compliment that my adc calibration registers accept?
J-M-L
2
which ADC ?
Mathematically, if
volt = val * referenceVoltage / 8388607
then
val = volt * 8388607 / referenceVoltage
(you'll need to play with precision, possible interval etc... to get to 16 bit)
Not sure that I understand your question, but isn't it just to swap "*" and "/":
uint32_t fromVoltage (double val, double referenceVoltage)
return (uint32_t)(val/referenceVoltage*8388607);
the register is 16bits will truncating the 16 most significant bit be okay?
the register is 16bits, val is 32bits if i truncate it wont i loose the sign bit?
Would this be correct>? This is my idea on how to preserve the sign. But there might be better ways like utilizing int16_t maybe instead of uint16_t
return (uint16_t) ( (val/referenceVoltage*8388607) & ( (val & 0x8000) >> 16) )
gfvalvo
7
How about answering that question?
How about showing a complete code that compiles so we can test?
J-M-L
8
At the moment the maths would deliver a double.
gives us more info about the ADC. if you can have negative values, using an uint32_t won't get you very far...
JohnRob
9
Your A/D must be a 23 bit (?) converter? (i.e. 8,388,607 steps)
what registers are you referring to? Does your A/D have specific registers for any offset?
I once read the Arduino does not do "double" values. What processor are you using?
system
Closed
10
