Hi folks, I'm trying to make a data logger which will take the time and date from an RTC, measure a voltage, and then record all this data to an SD card.
I have working code for the reading the RTC, and working code for writing to the SD card.
My query is this... I want to write the date, time, and voltage to the SD card in CSV format. So, I need to set up a CHAR array with the date, time, and voltage all separated with commas. However, the date, time, and voltage are INTs. How do I convert the INTs to CHARs?
For example:
if the minutes from the RTC are 28, this needs to be converted to two ASCII characters, the ASCII character for the number 2, and the ASCII character for the number 8 so that the two characters can be written to the CHAR array.
Any help appreciated!
Thanks,
Andy.
