How to convert char* to char ?
Hello all,
please how to convert char* to char ?
the last line of this code is error because the " var " is type of char but the " result " is char* ,
How can I take a number from the result to var so I can be use var as number like ' if ( var > 2 ) { }'
char result[ 10 ] , temp[ 10 ];
char var;
void setup(){
memset( result, 0, sizeof( result));
void loop(){
var = 123 ;
itoa( var, temp, 10);
strncpy( result, &temp[1],1);
var = result ;
To convert a char pointer to a char is meaningless and pointless.
Please, please remember to use code tags when posting code.
Write over all of the NULLS that the compiler put in result with more NULLS. Why?
As opposed to:
result[0] = temp[1];
? Why?
Or
var = temp[1];
? Why?
PaulS:
As opposed to:
? Why?
Or
var = temp[1];
? Why?
in my Example the result will be take one digit of the number, but if I write this code:-
 var = temp[1];
the var not take one digit because var not char*
The value in temp[1] is not a pointer, either.
