How to convert Char* to float?
Hi everyone, I really need your help. As the post topic mention I'm trying to convert char* to float. Can anyone provide me some solution on this aspect? Thank you.
He said a char pointer :slight_smile:
One way to do it is with function atof
If it is a char, I assume it is a digit character, '0' - '9'. If so, you could use:
   char c = '5';
   float x;
   x = (float) (c - '0');
The ASCII code for the '5' digit is 53 and for '0' (i.e., zero) it is 48. Therefore:
'5' - '0'
53 - 48
5
which is then cast to a float.
He said char*, but what he presumably meant was an array of char. Not the same thing at all.
On an eight bit Arduino, a "char*" is two bytes and a "float" is four.
Your question doesn't make a lot of sense.
If you're saying you've taken the address of a "float" and cast that address to a "char*" instead of the more natural "float*", then recovering the original "float" is trivial.
