how to convert "char xx[]" to "String" ?
I make a project that need "char xx[266]" to convert to "String"
here the sample code
char response[266];
int i;
String tmp;
char kosong[1];
boolean b = false;
if(b==false){
for (i = 0; i < 10; i++){
response*=i; *
  • tmp = response;*
  • Serial.println("tmp = "+tmp);*
  • b=true;*
    }[/quote]
    but it won't work, I also tried
    > tmp = response
    but still nothing happen
    I only got this from serial monitor
You make response=i ten times so when the loop is finished the response variable is equal to 9 and 9 is not a printable ASCII character.
  1. a string of 266 is damn long, why do you need that?
  2. You already have a string (char xx[]), why do you need the troublesome String? It's better left out.
It makes no sense to assign an integer to an array of char. Forget the "String" class - it is no good on arduino.
Grumpy_Mike:
ah my bad, thanks for answering.
septillion:
I just follow a tutorial and it use that so I just write it :smiley:
I would very much like to see that tutorial.. What is your code supposed to do?
