How to convert coordinates from AT+CGPSINFO returned value to redable format.
Hi Guys,
I am using SIM7600 Module, after executing "AT+CGPSINFO" this command getting location in following format, Also I have included TinyGPS++ library & used "gps.encode" function to convert coordinates of lat long but that function is not working.
AT+CGPSINFO; 1831.991044,N,07352.807453,E,141008,112307.0,553.9,0.0,113
Anyone knows how I can convert coordinates into actual lat long.
Thanks!
What format are the co-ordinates in ?
You presumably know where you are in the World (we dont) so how closely do the numbers;
represent your actual latitude and longitude ?
Oh, and its likley the co-ordinates are already 'actual lat long' but represented in one of the several formats used.
Hi, thanks for your reply. Latitude & longitude is getting you can see in the response which I posted but that format is different, degrees & minutes parameter is also included in the latitude & longitude, I want to remove those parameters (degrees & minute value) is there any available function?
Dont know if there is a direct function and TinyGPS++ is expecting as full GPS NMEA style sentence.
What was the anwer to the question I asked, you did not reply ?
+CGPSINFO: [],[<N/S>],[],[<E/W>],[],[],[],[],[]
+CGPSINFO:1831.991202,N,073.8801252,E,250311,072809.3,44.1,0.0,0
Answer: ddmm.mmmmmm
Example (Lat : 1831.991202, Long: 07352.807509)
Answer: dd.dddddd
Example: 18.5331867, 073.8801252
Its is the standard GPS NMEA format, I dont myself know of a ready made function to convert that, most GPS libraries will likley throw it out, they expect a full GPS NMEA sentence with checksum on the end.
However given that the format is;
DDMM.MMMMMMMM if you extract that from the buffer as a number then some sums will allow you to convert it in decimal degrees for instance.
Its effectivly the degrees digits then the minutes as a decimal, 0 to 59.99999999.
I wrote this function to convert a GPS latitude or longitude character string to degrees x 10^6, since with Arduino, 32 bit float variables cannot be used to store GPS coordinates accurately.
// decode individual NMEA lat/lon character strings in format DDDMM.MMMMM
// result is returned as long integer as degrees*10^6
// p is pointer to character string to be converted.
long parse_degrees(char* p) {
    char* minutes;
    char deg[]={0,0,0,0};  //up to 3 digits character  string for integer degrees
    double x;
    long d;
    if (strlen(p) == 0) return 0L;  //invalid input string
    if ((minutes = strchr(p,'.')) == NULL) return 0L;  //'.' not found, invalid
    minutes -= 2; //back up pointer to include two digits of minutes+decimal fraction
    x = strtod(minutes,NULL); //make into double
    memcpy(deg,p,minutes-p); //copy degrees, works OK with zero length string
    d = strtol(deg,NULL,10)*1000000UL;  //degrees to long int
    d += (long)(x*16666.667 + 0.5); //*1.e6/60.  add in minutes
    return d;
jremington:
// result is returned as long integer as degrees10^6
p) {
    char* minutes;
    double x;
    long d;
    d = strtol(deg,NULL,10)1000000UL;  //degrees to long int
    d += (long)(x
return d;
Thanks, that could be useful in the future.
