Datasheet? These very simple transmitters are designed only for OOK (on-off-keying),
and won't necessarily work as you are wanting (certainly I wouldn't expect any level
of linearity)
Whats that means is that the Transmitter sends data by the amplitude modulation of the transmitters carrier wave,
ie turning it on and off.
They cant be linearly modulated, which is what is needed for true AM transmission.
But what is your goal here, why do you need AM transmission?
Yes that's correct, but those simple 433.92 transmitters only support 2 binary states, on and off.
they don't support multiple amplitude states, or the ability to transmit multi byte symbols.
OK fair enough in which case those transmitters offer no real advantage over the OOK ones at low data rates.
Like you, I'm also wondering as to why the OP wants "AM", perhaps he wants to make a simple receiver/demod system himself in which case the OOK ones would probably make it easier for him as he just has to check for carrier versus no carrier.
