How to convert float to double using BME280 sensor for PID control
The BME280 sensor seems to return a float type value for the temperature and I would like to use it as my input for my PID controller. The problem is that the PID function has the input as a double. So how do you convert the sensor value from float to double ? Thanks !
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT); // PID(double*, double*, double*, double, double, double, int)
Input = bme.readTemperature(); // float Adafruit_BME280::readTemperature(void)
Unless you're using a Arduino Due, a float is the same as a double.
Please share your complete code for BME280.
More accurately, on the 8-bit Arduinos double is not implemented at all, but is instead just
an alias for float.
I can't help but include this tidbit that appeared recently in the 'off-topic' section of the AVR Freaks forum.
A man goes into a bar and orders 1.00000000009 root beers.
The bartender says "I will have to charge you extra for that, because it's a float."
The man responds "In that case, you might as well make it a double!"
Don
