How to convert gps data from serial monitor to TXT file
Hi guys, anyone can help me in converting gps data from serial monitor to a TXT file.
Where is this 'TXT' file located? Have you looked at the functions available in the SD library?
mza2307: Hi guys, anyone can help me in converting gps data from serial monitor to a TXT file.
Copy the text, paste it into a text editor. Save the data. There are no shortcuts when using the Serial Monitor application. Other serial applications do have the capability to save the data.
Instead of the serial monitor, use Putty or Teraterm to capture the data and create a log file.
