How to convert HEX string to equivalent DEC integer
Hi guys,
I need a little help again. I’ve been searching the web all day yesterday but haven’t found the answer yet…
I have a two digit HEX string such as
"C8"
and I need to convert this string to it’s equivalent decimal integer like so
200
This way I can compare ranges like
i > 150 && i < 255
which I can’t do at the moment since the value is a HEX string.
any help will be greatly appreciated!
which I can't do at the moment since the value is a HEX string.
First, some proof that "the value is a ... string" would be useful.
Second, is the string always two characters? If so, converting a value in the range '0' to '9' to a number is easy, as is converting a value in the range 'A' (or 'a') to 'F' (or 'f') is also easy. Then, multiply the first value by 16 and add the second value - where the values are the result of converting the 1st and 2nd characters.
Or, use strtoul().
PaulS:
First, some proof that “the value is a … string” would be useful.
Second, is the string always two characters? If so, converting a value in the range ‘0’ to ‘9’ to a number is easy, as is converting a value in the range ‘A’ (or ‘a’) to ‘F’ (or ‘f’) is also easy. Then, multiply the first value by 16 and add the second value - where the values are the result of converting the 1st and 2nd characters.
Or, use strtoul().
Yes the String is always a two digit number. Here is how the String is generated.
while (Serial.available() > 0) {
    char received = Serial.read();
    serialData += received;
    if (received == '\n') {
      String rssi = getToken(serialData, ',', 2);
String getToken(String data, char separator, int index) {
  int found = 0;
  int strIndex[] = {0, -1};
  int maxIndex = data.length() - 1;
  for(int i = 0; i <= maxIndex && found <= index; i++) {
    if(data.charAt(i) == separator || i == maxIndex) {
      found++;
      strIndex[0] = strIndex[1] + 1;
      strIndex[1] = (i == maxIndex) ? i + 1 : i;
  return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
rssi is then the two digit string.
No, it is not.
PaulS:
No, it is not.
Ok, now I'm confused :D What is it then? :fearful:
What is it then?
A String. Which is not the same thing as a string. Not by a long ways.
If you had a string, you could deal with it the way I suggested. There is a function to extract a string from the String, so you could do what I suggested. Or, there is a function to extract one character at a time, so you could do what I suggested.
Or, you could loose the String crutch, and just deal with strings.
Since you're looking for the newline character, why not use:
Serial.readBytesUntil('\n', data, sizeof(data));
I would also change data from String to char data[].
PaulS:
What is it then?
Ok so I have a String, is there an easy way to go straight to int? If not, how do I go to string?
Have you looked at the documentation for the String class? Have you tried anything? It would have taken less time to look and try than to ask.
Do you mean c-strings, aka a byte string stored in memory with a nul terminator appended?
C means 12.
So C8 means 12 x 16 + 8 = 200
It is the same concept as in decimal.
"214" means 2 x 100 + 1 x 10 + 4 = 214.
