Hello , i have a question so here it goes
I have this code that is copied from this forum, it reads the interupts , i am trying to read wiegand protocol , and everything is working great , i have just one question , when i print the received bits as ints i print them with this code
` for (int i = 0; i < bits; i++)
Serial.print((int)DataBits[i]);
as you can see , they are printed as int , so how can i take all these bits and send them to a webserver thorugh get request, how can i convert them to string like this "00110011101010010" and send them
#define MAX_BITS 100 // max number of bits
#define WEIGAND_WAIT_TIME 500 // time (milliseconds) to wait for another Weigand pulse.
uint8_t DataBits[MAX_BITS]; // stores all of the data bits
uint8_t BitCount; // number of bits currently captured
boolean FlagDone = true; // Set low when ready to capture data
volatile unsigned long WeigandWaitStartTime; // countdown until we assume there are no more bits
// interrupt that happens when INTO goes low (0 bit)
void ISR_INT0()
if (!FlagDone && BitCount < (MAX_BITS - 1))
DataBits[BitCount++] = 0;
WeigandWaitStartTime = millis(); // Re-start the timer
// interrupt that happens when INT1 goes low (1 bit)
void ISR_INT1()
DataBits[BitCount++] = 1;
pinMode(13, OUTPUT); // LED
pinMode(2 , INPUT_PULLUP); // DATA0 (INT0)
pinMode(3, INPUT_PULLUP); // DATA1 (INT1)
pinMode(18, INPUT_PULLUP); // DATA0 (INT0)
pinMode(19, INPUT_PULLUP);
Serial.println("RFID Readers");
// The two data lines idle HIGH
if (digitalRead(2) == LOW) {
Serial.println(F("WARNING: D0 line (on Pin 2) is not in a HIGH state. Wiring error?"));
if (digitalRead(3) == LOW) {
Serial.println(F("WARNING: D1 line (on Pin 3) is not in a HIGH state. Wiring error?"));
// binds the ISR functions to the falling edge of INTO and INT1
attachInterrupt(digitalPinToInterrupt(2), ISR_INT0, FALLING);
attachInterrupt(digitalPinToInterrupt(3), ISR_INT1, FALLING); // DATA1 (INT1)
attachInterrupt(digitalPinToInterrupt(18), ISR_INT0, FALLING);
attachInterrupt(digitalPinToInterrupt(19), ISR_INT1, FALLING); // DATA1 (INT1)
FlagDone = false; // Allow the collection of data bits
unsigned long currentTime = millis();
// Grab the
noInterrupts();
boolean done = FlagDone;
uint8_t bits = BitCount;
unsigned long timer = WeigandWaitStartTime;
interrupts();
// If we have started receiving bits, wait until we have not had a new one for a while
if (bits > 0)
digitalWrite(13, HIGH);
if (currentTime - timer > WEIGAND_WAIT_TIME)
noInterrupts();
FlagDone = true; // Stop accepting data
done = true;
interrupts();
digitalWrite(13, LOW);
// if the timer completed, process the data
if (done)
Serial.print("Read ");
Serial.print(bits);
Serial.println(" bits. ");
// we will decode the bits differently depending on how many bits we have
// see www.pagemac.com/azure/data_formats.php for mor info
unsigned long facilityCode = 0;
unsigned long cardCode = 0;
if (BitCount == 35)
// 35 bit HID Corporate 1000 format
// facility code = bits 2 to 14
for (int i = 2; i < 14; i++)
facilityCode <<= 1;
facilityCode |= DataBits[i];
// card code = bits 15 to 34
for (int i = 14; i < 34; i++)
cardCode <<= 1;
cardCode |= DataBits[i];
printBits(facilityCode,cardCode);
else if (BitCount == 26)
// standard 26 bit format
// facility code = bits 2 to 9
for (int i = 1; i < 9; i++)
facilityCode <<= 1;
// card code = bits 10 to 23
for (int i = 9; i < 25; i++)
cardCode <<= 1;
printBits(facilityCode, cardCode);
// you can add other formats if you want!
Serial.println("Unable to decode.");
// Display the received bits
// cleanup and get ready for the next card
noInterrupts();
BitCount = 0;
FlagDone = false; // Stop accepting data
interrupts();
void printBits(unsigned long facilityCode, unsigned long cardCode)
// I really hope you can figure out what this function does
Serial.print("FC = ");
Serial.print(facilityCode);
Serial.print(", CC = ");
Serial.println(cardCode);
