How to convert MAGA-3 Arduino integer code into Delphi Interfaces
const int AOUTpin=0;//the AOUT pin of the alcohol sensor goes into analog pin A0 of the arduino
const int DOUTpin=8;//the DOUT pin of the alcohol sensor goes into digital pin D8 of the arduino
int limit;
int value;
pinMode(DOUTpin, INPUT);//sets the pin as an input to the arduino
value= analogRead(AOUTpin);//reads the analaog value from the alcohol sensor’s AOUT pin
Serial.println(value);
if(value<200)
Serial.println(“Kamu Sadar”);
if (value>=200 && value<280)
Serial.println(“Alkohol Terdeteksi”);
if (value>=280 && value<350)
Serial.println(“lebih dari satu kamu minum”);
if (value>=350 && value <450)
Serial.println("Serius Kau Akan Mabuk ");
if(value>450)
Serial.println(“Kamu Peminum”);
delay (500);
So, what is it that you want help with ?
The thread title does not make sense to me.
There is no example of delphi programming using arduino mq-3 sensor … can not share the program just as an example of final task
frandofr:
Do you expect to finds one in this Arduino forum ?
 if(value<200)
      Serial.println("Kamu Sadar");
      Serial.println("Alkohol Terdeteksi");
      Serial.println("lebih dari satu kamu minum");
  if(value>450)
     Serial.println("Kamu Peminum");
What an inefficient way to test ranges. Each test has to be performed even if a match is found! It is better to use “else if” so that fewer tests have to be made. It is also more foolproof when using floating point numbers.
  if (value < 200)
  else if (value < 280)
  else if (value < 350)
  else if (value < 450)
