How to convert numbers from Binary to Decimal? [Hijacked]
//receiver
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(6,7); //CE,CSN pins RF24L01
const byte rxAddr[6] = "00001"; //address of unit 1
while (!Serial);
radio.begin();
radio.openReadingPipe(0, rxAddr);
radio.startListening();
if (radio.available())
char text[32] = {0};
char Amps[32] = {0};
radio.read(&text, sizeof(text)); //prints the word Amps1=
radio.read(&Amps, sizeof(Amps));// data received is giberish. need to clean it up
Serial.print(text);
Serial.println(Amps);
Moderator: This thread has two parts. Here is the other http://forum.arduino.cc/index.php?topic=539908.0
//transmitter_ASC basic
#include <SPI.h>
#include <RF24.h>
RF24 radio(6,7); //CE, CSN pins RF24L01
const int analogIn = A0; //ASC758 connection
int mVperAmp = 20;  // scale factor
int ACSoffset = 2500; //see bi directional offset
int RawValue = 0;
double Voltage = 0;
double Amps = 0;
radio.begin();
radio.setRetries(15, 5);//time,re tries
radio.openWritingPipe(rxAddr);
radio.stopListening();
 RawValue = analogRead(analogIn);
 Voltage =(RawValue/1023.0)*5000; //gets mV
 Amps =((Voltage-ACSoffset)/mVperAmp);
const char text[] = "Amps1 ="; // writes Amps1= to Rx unit
radio.write(&text, sizeof(text)); //check ())- its correct
//delay(50);
const char Amps[8];
radio.write (Amps, (sizeof Amps));
delay(3000);
What do you understand by the programming concept of "scope"?
Look, cut out all the messing around with analogue inputs.
Simply assign a known value, like 3.14 to a float variable, send it and see what you receive.
What you are trying to do is not impossible (far from it), but your approach to basic problem-solving is not helping you.
All text send and receive is disabled.
float Coco=3.144 return gibberish
float Coco=6.244 return gibberish
Screen shots are attached
thanks
1Doc1.pdf (184 KB)
Are you trying for a prize or something?
POST YOUR CODE, BOTH RX AND TX, NOT SOME MASSIVE PICTURES
//receiver
#include <SPI.h>
#include <RF24.h>
while (!Serial);
radio.begin();
//char text[32] = {0}; // for word Amps1=
char Amps[8];
//radio.read(&text, sizeof(text)); //prints the word Amps1=
radio.read(Amps, sizeof(Amps));// data received is giberish. need to clean it up
//Serial.print(text);
Im able to send text but somehow I cant float a simple number accross. The radio.write(&…,sizeof(…)); does not compile without the ‘&’ if float is used.
char Amps[8];If you send a float, you should receive a float.
It seems I have to keep repeating this.
And the fact that I asked you to post both tx and Rx sketches.
Are you sure you really want help, or are you just trolling?
I don’t know what … represents, but if the compiler expects it, maybe that’s a clue for you.
//receiver
#include <SPI.h>
#include <RF24.h>
float Coco;
while (!Serial);
radio.begin();
char Coco[8];
radio.read(Coco, sizeof(Coco));// data received is giberish. need to clean it up
Serial.println(Coco);
So, you’re send four bytes, and expecting to receive eight? (At least, I assume you’re sending four bytes, because, once again, you have omitted to post the transmitter code)
How’s that going for you?
//transmitter
#include <SPI.h>
#include <RF24.h>
  radio.begin();
float Amps = 3.142;
  radio.write (&Amps, sizeof (Amps));
  Amps += 1.0;
  delay(3000);
//receiver
#include <SPI.h>
#include <RF24.h>
  while (!Serial);
  radio.begin();
    float Coco;
    radio.read(&Coco, sizeof(Coco));
