how to convert small voltage value
hello my friends
I want to know how to convert small voltage value under arduino
someone can give me a sample program
thank you in advance
Can you make the question more clear?
Convert it to what?
convert data to voltage
in the case of small values
my program
it does not give good results for small value
float mesure1=0;
float tension1=0;
analogReference(INTERNAL); //
Serial.begin(9600); //
void loop() //fonction principale
mesure1 = analogRead(A2);
tension1=mesure1*1.1/1024;
Serial.println("tension ");
Serial.print (tension1,6);Serial.print("\n"); //Envoi de la tension au PC par la liaison série pour affichage dans la console
delay(5000);
How do you know?
It looks to me like you need to boost the voltage of the input signal.
thank you
my circuit generating signals with low values
and I want to recover these signals with their real valued
houssamucd:
thank you
You can't without an amplifier.
thank you my friends
