in this situation i want to get some value from firebase RTDB, and i tried to coverting that value to int, how to do that?
and this is my last code :
int setTemp = (Firebase.RTDB.getInt(&fbdo, "/setValue/tMax") ? String(fbdo.intData()).c_str() : fbdo.errorReason().c_str());
int setHumi = (Firebase.RTDB.getInt(&fbdo, "/setValue/hMin") ? String(fbdo.intData()).c_str() : fbdo.errorReason().c_str());
if (t >= setTemp)
lcd.setCursor(10, 0);
lcd.print(">");
lcd.print(" ");
Read the forum guidelines.
Use the IDE autoformat tool (ctrl-t or Tools, Auto Format) to indent the code for readability before posting code.
Post your code in code tags.
ok pardon me, it was editted, Thanks
From the name of the function I would try
int setTemp = Firebase.RTDB.getInt(&fbdo, "/setValue/tMax");
thanks for replying, now i know from library firebase client the fbdo.intData() it's already int, so i just put the code like this:
Firebase.RTDB.getInt(&fbdo, "/setValue/tMax") ? String(fbdo.intData()).c_str() : fbdo.errorReason().c_str(); int setTemp = fbdo.intData()
If you had included a link to the library you are using, I could have checked it myself.
I know from education and experience that assigning a char* to an int is rarely reasonable.
this the link of library that i use
🔥Firebase Arduino Client Library for ESP8266, ESP32 and RP2040 Pico. The complete, fast, secured and reliable Firebase Arduino client library that supports RTDB, Cloud Firestore, Firebase and Googl...
please tell me if i was wrong, thanks
Firebase.RTDB.getInt(&fbdo, "/setValue/tMax", &setTemp);
should do the trick.
With bool getInt(FirebaseData *fbdo, const char *path, int *target);
I'm not quite sure which of the functions you are really using, there are some variants,
but all include an overloaded function that specifies the target.
src/FirebaseESP32.cpp:bool FirebaseESP32::getInt(FirebaseData &fbdo, const String &path)
src/FirebaseESP32.cpp:bool FirebaseESP32::getInt(FirebaseData &fbdo, const String &path, int &target)
src/FirebaseESP32.h: bool getInt(FirebaseData &fbdo, const String &path);
src/FirebaseESP32.h: bool getInt(FirebaseData &fbdo, const String &path, int &target);
src/rtdb/FB_RTDB.cpp:bool FB_RTDB::getInt(FirebaseData *fbdo, const char *path)
src/rtdb/FB_RTDB.cpp:bool FB_RTDB::getInt(FirebaseData *fbdo, const char *path, int *target)
src/rtdb/FB_RTDB.h: bool getInt(FirebaseData *fbdo, const char *path);
src/rtdb/FB_RTDB.h: bool getInt(FirebaseData *fbdo, const char *path, int *target);
i'm sure i using this function.
So using bool getInt(FirebaseData *fbdo, const char *path, int *target); should work.
Glad it works.
I learned some things about a new library.
system
Closed
October 21, 2021, 10:24am
15
