There are a few different types of message, and I use the first byte to differentiate them. I've defined my different message types as structs. Simplified, they look a bit like this:
struct voltagesMessageStruct {
unsigned char messageType; // volts message type is 1
unsigned char voltsMain;
unsigned char voltsRes;
unsigned int voltsSolar;
// . . . continued until I've used up all 32 bytes
struct currentsMessageStruct {
unsigned char messageType; // amps message type is 2
unsigned int ampsLoad;
unsigned char ampsSolar;
unsigned char ampsReserve;
// make some instances
voltagesMessageStruct myVoltsMessage;
currentsMessageStruct myCurrentsMessage;
So I now have a 32 byte buffer, and checking, say, (myRXbuffer[0]==2) tells me it's structured like myCurrentsMessage. What syntax should I use to copy myRXbuffer into myCurrentsMessage?
Thoughts:
I want to copy it rather than just "cast" it, so I can continue to use the buffer for further readings
I could copy it long-hand, by going through each element of the struct and assigning the right bytes (or pairs of bytes, if the element is an int) but that requires a separate procedure for each structure, and is a pain to maintain.
The other direction happens on another Arduino (my transmitter). The same structs are defined there:
// Transmitter code:
// structs already defined in a header file; make some instances:
So, depending on what the transmitter wants to send, it just does this sort of thing:
// if it's time to send a "voltages" message:
radio.write (&myVoltsMessage, sizeof(voltagesMessageStruct)); // sizeof will always be 32 bytes by design
My problem is how to correctly and politely deal with the reception of what is now a blob of 32 bytes.
So at the receiver end, can I just do:
// if the first byte indicates it's a "volts" type message:
memcpy ( &myRXbuffer, &myVoltsMessage, 32 );
