how to copy a pointer to a 2-D array
int dz[4][2]={{0,4},{4,8},(8,4),(4,0)};
int* short_dist(int, int);
int* short_dist(int x,int y)
int sd,temp=100;
int ptr;
int i;
for (i=0;i<4;i++)
sd=sqrt(pow((x-dz_[0]),2)+pow((y-dz
[1]),2));_
_
if (sd<s)_
_
{_
_
temp=sd;_
_ ptr=(dz+(2i));_
[/quote]
i have declared the dz array as global (outside the func). The error given is
> In function 'int* short_dist(int, int)':
> error: cannot convert 'int ()[2]' to 'int' in assignment
plz help!!!
This would probably be for the line      ptr=(dz+(2*i));
I'm not sure what you want there, perhapsptr = &dz[i][1];
must be:
int dz[4][2]={{0,4},{4,8},{8,4},{4,0}};
maybe it could be:
byte dz[4][2]={{0,4},{4,8},{8,4},{4,0}}; //saves 50% RAM
hmm its ok i figured it out..
its
 ptr=*(dz+k)
yes i will implement the byte suggestion, thank you:)
