How to correct this error?
cannot convert ‘uint16_t* {aka unsigned int*}’ to ‘uint8_t* {aka unsigned char*}’ for argument ‘2’ to ‘void Block_Output(uint8_t, uint8_t*)’
I changed the Block_Output arguments to uint16_t, but I need them as uint8_t
A variable following this function has to be uint8_t.
extern uint16_t capture_data[CAPTURE_SIZE];
extern uint16_t capture_valid[CAPTURE_SIZE];
void Block_Output (uint8_t cnt, uint8_t *data) {
  while (cnt > 0) {
    UART_UDR = *data;
    checksum ^= *data++;
    cnt--;
    while (!(UART_UCSRA & UART_UDRE)) //while (!(UART_UCSRA & UART_UDRE)) - ORIGINAL
void SendCaptureData( uint8_t cmd, uint8_t ack ) {
  SendByte( 0x02 );
  SendByte( 4 + 2 * capture_cnt );
  SendByte( cmd );
  SendByte( ack );
  checksum = (4 + 2 * capture_cnt) ^ cmd ^ ack;
  Block_Output( capture_cnt, capture_data );
  Block_Output( capture_cnt, capture_valid );// -------ERROR HERE------------
  SendByte( checksum );
  SendByte( 0x03 );
Solved it. I declared the array variables as uint16_t instead of uint8_t
