hi
I am using Arduino Uno, servo motor and ultrasonic sensor for my project. When the sensor detect an object the servo motor will rotates.
I want to know how many times servo motor has rotated and this values need to record and store.. Can anybody provide me with the code.
I am attaching the present code I am using for the project.
#include <Servo.h>
#define trigPin 7
#define echoPin 6
Servo servo;
int sound = 250;
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
servo.attach(8);
long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance < 5) {
Serial.println("the distance is less than 5");
servo.write(90);
else {
servo.write(0);
if (distance > 60 || distance <= 0){
Serial.println("The distance is more than 60");
else {
Serial.print(distance);
Serial.println(" cm");
Best Regards,
Have you got a servo or a continuous rotation "servo" ?
So you mean "count the number of times you wrote a different value to the servo"?
Robin2
March 2, 2020, 8:08pm
5
sarinkayyankot:
Its MG996R Tower Pro.
The number does not men anything to me. Is it a continuous rotation servo or is it a standard servo that moves about 180deg between fixed limits?
If it is a continuous rotation servo then you will need something to identify when it makes a full revolution - an optical detector where the beam is broken by something attached to the motor shaft is one possibility.
...R
Hi
Its 180 degree servo motor.
OK
You need to detect when the distance becomes less than 5 rather than when it is less than 5, When that happens add 1 to a counter
See the StateChangeDetection example in the IDE
Robin2
March 2, 2020, 9:26pm
8
sarinkayyankot:
Then your use of the word "rotates" is strange. Do you mean how many times it "moves"?
You can keep track of that simply by incrementing a counter variable every time you issue a command to move the servo.
...R
Except for the fact that the code has these lines in it
if (distance < 5) {
servo.write(90);
if (rotationAngle>=360){
lap++; //number of times servo motor rotates
rotationAngle=0;
I think this counts the laps, isn't that it?
Where would the value of rotationAngle come from and how would it relate to a servo that can only move through 180 degrees ?
