Hello everyone, i'm doing a project using AMG8833 Grid Eye Thermal sensor for counting people or vehicle. I'm still confused about counting code for Arduino because when I search about counting with AMG8833 and no project found. Maybe everyone in here have a same project can share about this project or any advise for this project. And can this sensor use for counting people or vehicle? Thanks (Sorry for my bad language)
Yes, that sensor, when used with the appropriate software, can be used to count people in a room, for example.
It will NOT be an easy task to write that software, and it will never be 100% accurate. The problem is analysis of image data, similar to face recognition, etc.
Is it possible use Java programming for make this project? Or it can use Arduino programming?? I'm don't really understand at java programming.
And thanks for the advise.
Do you have the sensor? Have you hooked it up? Do you have example code to check it works?
