How to create 4 sensor PID wall follower
Hello, I have created a 1 sensor right PID wall follower, but I am trying to now make it for 4 sensors, two on each side. But I no clue how to apporach the problem, I am not sure if I should combine the error rate for the right/left 2 sensors. And I am not sure how I apply a PID to left and right side to make the robot stays central.
Here is the sample code for a right wall PID follower:
#include <Arduino.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <MeAuriga.h>
//Encoder Motor Declare
MeEncoderOnBoard Encoder_1(SLOT1); // Declare encoder motors
MeEncoderOnBoard Encoder_2(SLOT2);
//Ultrasonic Declare
MeUltrasonicSensor frontUltraSensor(PORT_9);
//PID Declare
int desiredLength = 6;
int speedValue = 100;
int threshold = 5;
int error = 0;
int lastError = 0;
int proportional = 0;
int integral = 0;
int derivative = 0;
int pidValue = 0;
float kP = 5.5;
float kI = 0.01;
float kD = 0.3;
//Motor Declare
void isr_process_encoder1(void)
      if(digitalRead(Encoder_1.getPortB()) == 0){
            Encoder_1.pulsePosMinus();
      }else{
            Encoder_1.pulsePosPlus();
void isr_process_encoder2(void)
      if(digitalRead(Encoder_2.getPortB()) == 0){
            Encoder_2.pulsePosMinus();
      }else{
            Encoder_2.pulsePosPlus();
void setup(){
    //PWM Motor Setup
    attachInterrupt(Encoder_1.getIntNum(), isr_process_encoder1, RISING);
    attachInterrupt(Encoder_2.getIntNum(), isr_process_encoder2, RISING);
    //Set Pwm 8KHz
    TCCR1A = _BV(WGM10);
    TCCR1B = _BV(CS11) | _BV(WGM12);
    TCCR2A = _BV(WGM21) | _BV(WGM20);
    TCCR2B = _BV(CS21);
void loop(){
  if (frontUltraSensor.distanceCm() <= 6){
        Encoder_1.setMotorPwm(0);
        Encoder_2.setMotorPwm(0);
        exit(0);
   int distance = getUltrasonicTopRight();
   error = distance - desiredLength;
   if (abs(error) < threshold){
      integral = integral + error;
   }else{
      integral = 0;
      derivative = error - lastError;
      lastError = error;
      pidValue = error*kP + integral*kI + derivative*kD;
   if (pidValue > 100){
      pidValue = 60;
   else if (pidValue < -100){
      pidValue = -60;
    Encoder_1.setMotorPwm(-speedValue + pidValue);
    Encoder_2.setMotorPwm(speedValue + pidValue);
    Encoder_1.updateSpeed(); //update speed
    Encoder_2.updateSpeed();
